It is currently Mon Sep 21, 2026 4:46 pm
Post Posted: Thu Jan 10, 2013 3:07 am
Hi AZ,
I'm fitting a baleno g16b into my sierra. I've already found the right info on here on how to modify the sump for the crank angle sensor but I can't really find much info on modifying the oil pickup. My understanding is that you graft the sierra and baleno pick up tubes together? Whats the best way to do this?
Whats the best way to weld them...would mig work or would it need to be tig?
any pictures or advice would be great :D
thanks.
Post Posted: Thu Jan 10, 2013 5:12 am
I cut and shut the pickup at the oil pump fitting end, saves having to modify the sump baffle. Just need to make up a support bracket for the other end.
Vehicle: Clown Car..
Post Posted: Thu Jan 10, 2013 5:28 am
Id probably braze it....
http://www.offroadexpress.co.nz/Forums/ ... 23&t=28634
http://www.zukikrawlers.com/showthread.php?t=48353
http://www.suzuki-forums.com/suzuki-jim ... -swap.html
Vehicle: 1984 NT High Top
Post Posted: Thu Jan 10, 2013 9:26 am
At the fitting end. Easy job.
I used a crappy gasless mig so had to full a few holes.
I would say come check out mine but I just glued the sump on.
Currently doing this conversion as well.
Post Posted: Thu Jan 10, 2013 4:17 pm
thanks for the advice and pics guys. So brazing it would probably be the best method for getting a leak free joint? I don't have access to a oxy so worst case would the mig suffice or would the joint be to hard to seal with the mig?
Post Posted: Thu Jan 10, 2013 5:06 pm
Mig is fine mate. It's thin steel but it's not too bad hey.
Post Posted: Thu Jan 10, 2013 5:10 pm
FYI piss that tapatalk signature shit off unless you want a bus ride. :thefinger:
Post Posted: Thu Jan 10, 2013 5:28 pm
Fuck me isn't that the second time it's come up since the first time you had a whinge.
Your onto shit quick
Post Posted: Thu Jan 10, 2013 5:37 pm
just giving you a heads up so you don't get the ban...
Post Posted: Thu Jan 10, 2013 6:00 pm
Inspired me to see if I could remove it and it's done.
That should keep you happy till Jakes back online
Post Posted: Sun Jan 13, 2013 6:05 am
If you look at that pic of the pickups it shows the small diameter 1300 pickup. Later model 1300's have a larger diameter pickup tube, same as 1600. Source the larger tube 1300 pickup and weld the 1600 end on that way you won't restrict oil flow.
Post Posted: Sun Jan 13, 2013 6:31 am
What was that fitted to?
A couple of the pics above are mine, I was concerned about restricting the oil flow but it doesn't seem to have had too much effect. The pipe was from the original 1.3 engine in my 1986 SJ413K. The conversion was done on a very tight budget with limited tools - if I was doing it again I think I would make up a whole new pipe as its not a hugely complicated shape, or maybe try to source a GV pipe and sump.
Edit: Gosh, I just read that newspaper!
Post Posted: Sun Jan 13, 2013 12:54 pm
ahh bugger, I just finished the pickup yesterday using the smaller diameter 1300 pickup. :cry:
Post Posted: Mon Jan 14, 2013 1:33 am
all good :D I found a later model sierra pickup/sump and modified them for the g16b this arvo.
Post Posted: Mon Jan 14, 2013 5:51 am
but did you take the appropriate pics to then share your experience!? ;)
Users browsing this forum: No registered users and 72 guests
