It is currently Tue Nov 03, 2026 10:08 am
Vehicle: 92 Suzuki Sierra WT
Post Posted: Sun Jan 20, 2013 8:14 pm
Hey, i got a few things sitting in the shed i would like to get rid of. At this point in time i am not willing to post any parts. If my prices are a little out there could let me know what a reasonable price for the item would be as i have no idea what its worth.
CONTACT: Shoot me a pm or a message on 0410 427 330 i will try to reply promptly.
ITEMS:
1: 3.9 third member (sierra)
2: Holden Drover guards and nose cone (guards have been chopped but not finished off)
3: WT Sierra steering box and drag links
4: Stock WT Sierra transfer case gears (removed after fitting 4.9 transfer gears)
CONDITION:
1: Good condition. Back lash seems fine, teeth are good and spins fine. It has been sitting for a while.
2: OK condition. Guards have been cut to allow bigger tyres to be fitted, driver side has been finished but passenger needs little work to complete. Has rust in all the usual sierra spots (see photos). Also a dint on the driver side front corner.
3: OK condition. Steering box is a bit sloppy but does not leak and the tie rod ends are on there way out. I bought them as a spare in case i bent mine for a quick fix.
4: Good condition. Seem to be good but the counter shaft has slight wear marks (see photo). These were the gears i removed from the transfer case when i installed my 4.9 reduction gears.
PRICE
1: $100
2: $50
3: $50
4: $50
PHOTOS:
1
2
3
4
Post Posted: Sun Jan 20, 2013 8:52 pm
For #5, you can throw the prop shaft and bearings in the bin. They are knackered. Case hardening is long gone.
Post Posted: Sun Jan 20, 2013 9:39 pm
Thanks mate I'll turf them then. No point selling useless gear.
Post Posted: Sun Jan 20, 2013 9:41 pm
They are consumable parts unfortunately.
The gears may be of use to someone wanting to make a rocklobbster case from a 1L transfer.
Post Posted: Tue Jan 22, 2013 3:59 pm
You interested in selling the steering drag links separately?
Post Posted: Tue Jan 22, 2013 5:13 pm
Yer I can do that man. How about $50 for the pair sound?
Post Posted: Thu Jan 24, 2013 7:36 pm
Bumpity
Post Posted: Sun Jan 27, 2013 5:17 pm
Bump it to top! I want this stuff gone some make a reasonable offer and I'll probably take it.
Post Posted: Thu Jan 31, 2013 7:24 pm
Bumpity!!!
Vehicle: SJ413 WT
Post Posted: Fri Feb 01, 2013 8:35 am
Excuse my noobness, but is #1 a WT front diff?
I'm chasing a rear (which I think is a 4.1 ratio?) as my crown ring and pinion gears are shagged.
If this will do the job, I might be interested.
Post Posted: Fri Feb 01, 2013 8:37 pm
Hillbilly sorry mate I don't have any springs man.
Toastysteve it will not work for your application as its a 3.9 ratio.
Post Posted: Sat Feb 02, 2013 1:26 pm
No.2 is a Drover clip not Sierra.
The headlight adjusters are different...
Post Posted: Sat Feb 02, 2013 4:15 pm
Ok mate l'll edit it thanks for letting me know.
Post Posted: Thu May 02, 2013 3:36 pm
Still got these V V V , what's the collar teeth like on the high speed output gear like?
Post Posted: Thu May 02, 2013 4:14 pm
I think I have one Paul, will check for you.
Post Posted: Thu May 02, 2013 8:54 pm
They seem fine to but I will take a better photo tomorrow and put it up for man.
Users browsing this forum: No registered users and 20 guests
