| Author |
Message |
sbyard
Joined: Sat Oct 10, 2009 10:30 pm Posts: 189 Location: Perth, WA
Vehicle: 89 Softtop Sierra, 6.5's, 30's
 Posted: Thu Jan 24, 2013 1:52 pm |
Currently replacing the axle seals. Have got to the stage where the new axle seal is installed and I've hit a road block - the axle wont go in all the way so that the cv joint sits in the ball joint.
Is there any particular trick to getting it it? I've tried spinning it while applying pressure. The write ups I've read don't say anything about this. Have I missed something?
Cheers,
Sam
Fatzook
 Posted: Thu Jan 24, 2013 2:05 pm |
No tricks. Just put some downward weight on the cv as you push it in, and rotate it slowly from left to right until it pops into the centre.
sbyard
 Posted: Thu Jan 24, 2013 2:54 pm |
Thanks for that fatzook. Realised I was having a blonde moment and figured it out. Just put the tin/rubber/felt on. Here's hoping it went on the right way!
sbyard
 Posted: Thu Jan 24, 2013 4:20 pm |
I snapped one of the kingpin bolts!
Just waiting on the third stupid fuck up for the day...
Can any one point me in the direction of where I can acquire a new kingpin bolt?
EDIT: Found some on ebay.
steve
Joined: Sun Jun 11, 2006 11:30 pm Posts: 7681 Location: Brisbane
Vehicle: 75 Cruiser
 Posted: Fri Jan 25, 2013 3:40 pm |
these kinds of things happen to me also,.... starts out as an easy 30 minute job, then something stuffs up and it takes the whole day.
royce
 Posted: Fri Jan 25, 2013 3:48 pm |
steve wrote: these kinds of things happen to me also,.... starts out as an easy 30 minute job, then something stuffs up and it takes the whole day.  Good thing I dont post about the mini on here
christover1
 Posted: Fri Jan 25, 2013 4:13 pm |
royce wrote: steve wrote: these kinds of things happen to me also,.... starts out as an easy 30 minute job, then something stuffs up and it takes the whole day.  Good thing I dont post about the mini on here  I had a Moke for 25 years, I understand
sideways
Joined: Fri Oct 29, 2010 1:53 pm Posts: 5946 Location: Northcliffe, W.A.
 Posted: Fri Jan 25, 2013 4:58 pm |
I have a mini and I understand.
sbyard
 Posted: Mon Jan 28, 2013 6:27 pm |
The third stuff up was another bolt. Hub body bolt snapped - I mis read the torque settings - it was measured in in/lb not ft/lb....
Ah well I got a thorough induction on the new torque wrench, on how to read and re-check service manuals, and I'm due to learn how to remove snapped bolts when I'm next back at home...
There's always a silver lining.
