It is currently Mon Aug 03, 2026 7:47 pm
Vehicle: Suzuki Vitara JLX 1991
Post Posted: Sun Feb 10, 2013 8:08 pm
Hi all,
I have a SWB 1991 Vitara. Looking for Roof racks and not sure where to look or what t look for? There is currently nothing on the roof or any tracks etc.
Fresh slate!
Any Tips?
Jase
Post Posted: Sun Feb 10, 2013 8:11 pm
Bit hard to see I know but this is what mine has. Not sure where to start looking to buy them tho
Post Posted: Sun Feb 10, 2013 8:51 pm
I dont mean to be a newby but how do they stay on? Stuck down? Bolted?
cheers
Post Posted: Sun Feb 10, 2013 9:03 pm
Held down by hopes and dreams.....
I assume they're bolted
Post Posted: Sun Feb 10, 2013 9:07 pm
the rola track mounts are pop riveted to the roof skin. most installs only get a few rivets, mine had 3 at each end & 4 spread along the remaining lenght, same for both sides.
got any self serve wreckers around your way? most magna's, camry's, mazda's have factory fitted rola equipment, take a cordless drill, torx bits, point nose plyers & help yourself to whats on offer.
heaps of threads on rola racks, this is one of many viewtopic.php?f=5&t=29823&hilit=roof & another viewtopic.php?f=5&t=21820&hilit=roof+rack
Post Posted: Sun Feb 10, 2013 9:23 pm
Cheers mate will take a look at thanks for the advice. up up and away. Armsup
Post Posted: Mon Feb 11, 2013 3:46 pm
Hi guys.
Ok went to my local wrecker and found a few different types. Only 1 had the rail mount system. Here a a few pics. The first ones here are off a VS or VP commodore. They had long tracks and by the looks of them can you tell if these are Rola Racks or Rhino etc?
Also there seems to be a theft screw on them to prevent removal how do I get them out when trying to get them off when i go on Saturday? Is there a special tool? Am i guessing its the Torx drill bit? I have plenty of those so shouldnt be a worry.
I might have the cut the tracks down but they should work. Also there seems to be a rubber type seal under the tracks. If this is broken and cant be taken off properly do they still require the rubber seal on the bottom of the tracks?
Post Posted: Mon Feb 11, 2013 3:49 pm
Here is another set of Rhino Racks i found? I dont think these are the right ones though?
Post Posted: Mon Feb 11, 2013 3:50 pm
And the third and final set look like the clip over type. I dont think these would suit either?
Post Posted: Mon Feb 11, 2013 4:06 pm
it's a allen key security fitting, you can make one or buy them from a tool shop or go to a roof rack place & buy the tool.
grab the ones of the commodore & cut down to suit.
Post Posted: Tue Feb 12, 2013 5:47 pm
ok, good news and bad news.
When i was pulling off one of the tracks i shredded a track screw second in from the end screw. I had to cut it off with a hacksaw. Originally the tracks were 1600mm long. I had the cut the other down to 1200mm at the point of the shredded screw to get it off the wrecker car otherwise it was going to be a complete waste of time. I am going to cut down the 1600mm track down to 1200mm to match the other.
Question is will 1200mm track lengths going to be ok. Is it still going to be as strong etc or are they to short?
Here is a few pictures.
Post Posted: Tue Feb 12, 2013 5:49 pm
plenty long enough, set the track so the end of them is about where the roof ribs start. you wont need the racks that far forward.
Post Posted: Tue Feb 12, 2013 5:59 pm
Phew.. thats good news. Yeah I was going to put them towards the rear anyway. It was just for illustration purposes.
Another question I have is the roof racks are far to wide and will need to be cut down. Whats the best way to get a flush straight cut? I was going to use a hack saw but Its hard to get a good nice flush neat cut. Any tips?
Post Posted: Tue Feb 12, 2013 6:04 pm
drop saw?
mark it up with some masking tape to get a nice straight line around it & take it easy with the hack-saw.
my rails were set right out near the edge of the roof, think it was a rail thickness in from where the "gutter" is
Vehicle: 93 Vitara -itty bitty lift
Post Posted: Tue Feb 12, 2013 8:26 pm
good old fashioned mitre box and take it slow......or a drop saw
Post Posted: Tue Feb 12, 2013 8:51 pm
also guys do I need to get the backing rubbing? I noticed when I took the tracks off there was a rubber type foam seal underneath? I just removed most of it with a razor becuase it was all hanging off after I removed the track from the wrecker car.
Post Posted: Sat Feb 16, 2013 5:14 pm
Well I finally got the roof racks on. I ended up grinding the end off a cheap rivet gun so it would slide into the channel of the rack mounts. Worked great. 4x 4.8mm rivets into each side and she is done.
I didnt bother putting the end caps on the racks just left them off. as it didnt make it look any better in my opinion.
Gave them a spray in the booth with a matt black paint job.
All I need now is vortex basket or similar and some tie downs. Brilliant.
Post Posted: Fri Mar 29, 2013 6:02 pm
Grave dig. I just fitted the same type of roof racks to my Vitara. Would like to at some stage fit a Awning to it. Can't seem to find any acc fittings to suit. What have others done?
Post Posted: Fri Mar 29, 2013 6:11 pm
sport racks? you can chop a bit of the center strip out and slide a channel nut in and hang a bracket off
ive got the nuts here somewhere
Post Posted: Fri Mar 29, 2013 6:20 pm
JasonSelmes wrote:
Same as these ones. Well chop chop, find ya nuts and I'll take them :rofl: :rofl: :rofl: :rofl:
Post Posted: Fri Mar 29, 2013 6:24 pm
just put the pair of rhino bars you've got sitting over by the far wall on :wink:
Vehicle: LWB Sierra & XL7
Post Posted: Fri Mar 29, 2013 6:39 pm
I drilled straight through the bar and bolted the bracket for the awning directly to it, Slide the awning on and done.
'92 Vitara & Camper trailer
Post Posted: Fri Mar 29, 2013 6:49 pm
Only got 1 rhino bar on the wall now. Used the other one for the Rodeo for the light bar.
I did think of that buzbox but thought there would be some type of fitting thingo for them :-)
Post Posted: Fri Mar 29, 2013 6:58 pm
Ahh for Rhino bars, yes they are available, Mine are Rola and I couldn't find anything anywhere, the rhino adapters are about 1mm too tall and about 3mm too wide for the track of the Rola, I got the shits and just drilled through the bar. Off the top of my head I got 4 blocks, 2 screws and 2 tie down eyelets for about $25 or so.
Post Posted: Fri Mar 29, 2013 7:13 pm
aah righto. Was looking at these but they might not fit and looks like they are wrong anyway
http://www.rhinorack.com.au/AccSubCateg ... 14_40.aspx
Users browsing this forum: No registered users and 16 guests
