It is currently Wed Jul 29, 2026 3:47 pm
Vehicle: 99 Jimny
Post Posted: Thu Feb 14, 2013 12:13 pm
Hey guys
So I've just recently shagged my 2nd rear ring and pinion on my jimny. i thinking of doing hilux diff conversion.
I've just recently upgraded all my suspension with ORA radius arms, springs, avo shocks and other bits and pieces. so that all may b a waste...
I'm puzzled on which route to take on this;
hilux diffs reusing all the jimny suspension components
hilux diffs with 3/4 link setup and jimny shocks and springs
hilux diffs with 3/4 link setup and custom spring/air shock setup
thanks guys really need some input on this
Matt
Post Posted: Thu Feb 14, 2013 4:12 pm
There is something wrong mate, if your setting it up that's why, if a guy is setting it up his doing his job wrong...
But if your just interested in a Lux swap then its a cool idea.
What's 3/4 suspension?
Post Posted: Thu Feb 14, 2013 4:15 pm
3/4: 3 and 4 link. Assuming 3link+P front and Tri-4link rear.
Vehicle: 00 Jimny, 63 Haffy
Post Posted: Thu Feb 14, 2013 4:17 pm
You will want a a bundeara rear and a hilux front or 70 series front and rear, but not a rear hilux (its not offset). lux/bundy are probably a bit narrow.
If your going to the effort of changing the diffs you will want to change the radius arms, yes. there are a few options, landrover arms flipped like gwagens for radius or custom 3link+panhard like Joshes are possibly the best bets.
You will be able to sell the arms for resonable coin so no big loss there. you can probably reuse the rest.
You will be able to just cut all the suspension mounts off the old housing and it will all mount up easily I think.
with 70 series you should be able to engineer 34s as they ship with 750 16s as a factory option.
EDIT: I just checked the axel widths thread, hilux width isnt too narrow. but its not much wider than standard.
Vehicle: 99 Jimny
Post Posted: Thu Feb 14, 2013 4:29 pm
yeah mate i did the diff, blacklash and contact all setup sweet (i use to work for holden/suzuki dealership)
original diff destroyed everything all teeth and axles, this one i think ive lost a tooth on the pinion coz i hear it skip once only every 50-100km, mainly just after clutch in as why i think its the pinion.
i have been waitin for front cv and shafts to go, but havnt yet. im not keen on spending the money to do rear full floater, and front hd shafts and cvs, if the r&p r still going to give me hassle.
yeah like 3 link front and 4 link rear, not sure.
just the fact of doin all the calculations to make a link suspension scares the shit out of me haha
would it work reusing my springs and shocks with a link setup?
Post Posted: Thu Feb 14, 2013 4:41 pm
Springs and shock will work, just less effectivley at controlling unsprung mass. Tho, the extra 100Kg of diff i would say that would be equal difference to a driver-passenger and bar with winch.
If it was going to road driven/engineered, i would 3-link front and rear cause the tank is in the way in the back on Hilux diffs
But if it was a comp truck, i would buy 60/80series diffs, put a fuel cell in the boot, 3-link the front and 4-link the rear.
Vehicle: 99 Jimny
Post Posted: Thu Feb 14, 2013 4:46 pm
Thanks mate, was thinking about the fuel tank with 4link. so 3 link + panhard front and rear would be the go then.
whats the best way of doin all the maths, seen afew programs for calculations on sites like pirate 4x4
Post Posted: Thu Feb 14, 2013 4:47 pm
got any reduction gearing to counter act the larger tyres or are you just scull fucking the clutch off road?
31zook seems to be able to wheel some pretty hardcore terrain & push it pretty hard & keep his junk in 1 piece. :wink:
Vehicle: 99 Jimny
Post Posted: Thu Feb 14, 2013 4:57 pm
all damage done with stock gearing. the transfer and diff went at the same time at powerlines :/
i had a sierra transfer with 6:4 gears (way too low) ready for it so thats in it now to keep it driving.
i was hopin gearin would stop me blowing shit up, coz im pretty rough haha, ive done in 2 g13's, 2 rear diffs and a transfer...
but now i got gearing and a blown diff, so will never know :(
Post Posted: Thu Feb 14, 2013 5:04 pm
apparently, the old mechanical sympathy goes along way.
Post Posted: Thu Feb 14, 2013 5:06 pm
Sounds like a driver problem..
Post Posted: Thu Feb 14, 2013 5:09 pm
that would be it then....
Vehicle: 99 Jimny
Post Posted: Thu Feb 14, 2013 5:49 pm
Yeap guilty dont go easy on it, thats for sure
Vehicle: 2012 jimny
Post Posted: Fri Feb 15, 2013 8:03 pm
Sorry to thread hijack but can other diffs/transfers be engineered legally onto a daily jimny? If so that makes me happy for some reason lol
Post Posted: Fri Feb 15, 2013 8:38 pm
Short answer, yes.
Post Posted: Fri Feb 15, 2013 9:34 pm
Didn't joe and kenn go all American on Suzukis arse because Kenn kept on braking back diffs or something?
Vehicle: 2012 jimny
Post Posted: Fri Feb 15, 2013 9:43 pm
Cool thanks
Post Posted: Sun Feb 17, 2013 12:48 pm
No, we didn't organize a pool party with bikini clad women that turned into a porn set.........nor did we buy a Jeep and go homosexual...
We built custom housings to suit our custom applications. The diff centres (whilst Vitara) remained Suzuki.
If you are having issues it's because the Jimny has an issue with quality control in regards to rear diffs. Chuck a Maruti rear diff in it and I bet you won't break one. BUT, make sure your housing is straight first.
Post Posted: Sun Feb 17, 2013 3:45 pm
X2
I smashed a 4.3 rear diff and smifkid smashed x2 4.11 rear diffs, but once we both went to the maruti centres neither of us had a issue after that
Vehicle: 99 Jimny
Post Posted: Sun Feb 17, 2013 4:33 pm
Sweet does the maruti come in a 4.09?
Post Posted: Sun Feb 17, 2013 4:38 pm
4.11/4.09 same thing
Post Posted: Sun Feb 17, 2013 5:09 pm
Aaaand thats why youre a boilermaker :lol:
Vehicle: 99 Jimny
Post Posted: Sun Feb 17, 2013 5:19 pm
lol :) mite b a option then thanks
Post Posted: Sun Feb 17, 2013 5:24 pm
There is very little to no difference between the 2 no? Even if there was its not going to cause a issue.
Users browsing this forum: No registered users and 771 guests
