It is currently Fri Sep 25, 2026 5:14 am
Vehicle: '94 suzuki maruti
Post Posted: Wed Feb 20, 2013 5:48 pm
i just bought a new reverse light switch, the thing that plugs into the gearbox... and now when i put the car in reverse, the fuse blows. i can bridge the 2 terminals where it plugs into the loom, and the reverse lights come on and fuse remains intact, same thing if i plug the reverse switch in but dont screw it into the gearbox and push the little button on the end... but once its screwed in, it just blows the fuse.
anyone else ever had this issue? sounds most likely to be the reverse switch is faulty, not a wiring issue. any thoughts?
Post Posted: Wed Feb 20, 2013 6:06 pm
Remove the switch and check for continuity from either of the terminals to the switch body.
Post Posted: Wed Feb 20, 2013 7:09 pm
soon as i find my bludy multimeter i will... seems to have just vanished >.<
Post Posted: Wed Feb 20, 2013 7:42 pm
must be earthing out
Post Posted: Wed Feb 20, 2013 10:08 pm
There have been switches that earth out when fully depressed - if you have one of those - stick a washer under the switch
Post Posted: Thu Feb 21, 2013 8:40 am
What lights are you trying to run for reverse?
Post Posted: Thu Feb 21, 2013 2:06 pm
2 tiny LED lights that draw about half what the original reverse lights do... worked fine with the old switch, only replaced because one of the wires broke off the switch itself
Post Posted: Mon Feb 25, 2013 1:02 pm
just to update: received my new one and it works no dramas. relieved its not a wiring issue, thats for sure!... was purchased on ebay from "4wd_products". i certainly wont hesitate to buy from them again, extremely easy to deal with, replied to my messages within a matter of hours and sent out a replacement the following day.
Users browsing this forum: Google [Bot] and 129 guests
