It is currently Wed Sep 23, 2026 9:24 pm
Post Posted: Mon Feb 25, 2013 9:48 pm
I have 5.12 ratio vitara ring and pinion gears fitted. I have fitted a lockrite locker and am getting a bit sick of the 'click click bang bang'.
I can get a cheap vitara rear axle (hub to hub) and am considering swapping out the whole diff centre to swap it back to an open diff. Provided the donor ratio is the same - I have read there are numerous ratios depending on year/engine/gearbox - will the rear physically fit into the Sierra pumpkin? Are all vitara rear side gears 26 spline?
OR - bigger job - muck around with shimming the locker to make it tighter. It was great when I first put it in but after 6 months has loosened up ... clicky clicky bang bang ...
No I don't have the budget to fit a chinsoong airlocker.
Thanks for your help
Post Posted: Mon Feb 25, 2013 10:06 pm
Won't fit.
Vitara rear 3rd is substantially bigger than sierra.
Post Posted: Tue Feb 26, 2013 7:06 am
thanks - guess I'll get the shims out ..... bugger
Users browsing this forum: No registered users and 198 guests
