It is currently Sat Sep 26, 2026 5:40 am
Post Posted: Wed Feb 27, 2013 6:30 pm
hi there anything i need to modify or change other than the bumpers?
Post Posted: Wed Feb 27, 2013 8:03 pm
loosen hose clamp on fuel filler for extra length
interior gearstick boot wouldnt fit on with 2 inch
Post Posted: Thu Feb 28, 2013 5:17 pm
cheers larry, may just need to cut the boot a bit
Post Posted: Thu Feb 28, 2013 5:26 pm
shave the transfer lever knob down as per ninjamoses & you might still need to clearance the hole for the gearstick in the transmission tunnel or refit the gear stick back to front... it's sort of a bit of trial & error, but with only 1" you shouldn't have too many drama's.
EDIT: loosen the LHS brake line where it passes through the inner guard & reposition it so it faces down to get a little extra slack out of it.
Post Posted: Thu Feb 28, 2013 6:54 pm
cheers atari
Users browsing this forum: No registered users and 76 guests
