It is currently Tue Nov 03, 2026 2:29 pm
Vehicle: 98 jimny
Post Posted: Thu Mar 07, 2013 5:13 pm
I know another gearing question, but I want to get 120kph out of the jimny with roughly 3-3.5k rpm at the moment I am 4150rpm for 100kph I need some hwy tyres and want to know if 32s with help with my revs if not 33s maby, I'm light on the foot too so the added stress shouldn't be a problem and will only use on the road, and yes I don't mind changing gears on hills as my work truck is a dihatsu delta...
Vehicle: 98 jimny
Post Posted: Thu Mar 07, 2013 5:15 pm
Forgot to say I'm running 31" bighorns
Post Posted: Sat Mar 09, 2013 9:29 pm
When you quote speeds is that what the speedo says?
You mention 24% reduction in the title, is that part of the equation?
The 1.3 will never push 32s to 120 while only doing 3500rpm.
With your 31s your speedo would be out by roughly 15%, therefore when it reads 100 you are actually doing 115.
Vehicle: 98 jimny
Post Posted: Sun Mar 10, 2013 1:39 am
Yeah my speedo is out by just over 10kph, so when I'm doing 90 I'm somewhere around the 100-105 I just want to lower the revs a little bit and was thinking that extra bit of tyre might drop it enough
Post Posted: Sun Mar 10, 2013 6:46 am
No, the bigger the tyre the harder the motor will need to work to move them.
Why not try 40s and see If you can idle at 100...
Vehicle: Suzuki Jimny 2010
Post Posted: Sun Mar 10, 2013 7:00 am
Even if you did get it to rev at 3500 at 120, it'd take you the whole pacific highway to get to 120 cause the gearing would be so high! Jimnys rev dude, its just how they are :) me and 31zook will be driving to Coffs doing around 4150-4500rpm the whole 360kms... It's part of the fun :)
Vehicle: 98 jimny
Post Posted: Sun Mar 10, 2013 7:38 am
Fair enough so ill just buy a set of 31 all terrains then, how many jimnys are coming on the coffs drive?
Post Posted: Sun Mar 10, 2013 8:00 am
Around 5-6 I think?
Users browsing this forum: No registered users and 376 guests
