It is currently Sat Oct 03, 2026 4:57 am
Post Posted: Thu Mar 14, 2013 10:25 pm
Hey all
I'm having problems with my gearbox on occasions, my problem is that once you are
in gear whilst driving it won't allow me to change gear at all, an happens in every gear.
But if I turn the car off, I can choose any gear no problem but the moment I start the car I'm unable
to select gears
Its a 1991 Suzuki Sierra with a G16a engine conversion.
Any ideas on what may be causing this please reply as this is my daily driver.
Thanks
Post Posted: Thu Mar 14, 2013 10:28 pm
Sounds like a clutch problem to me.
Have you tried adjusting the clutch?
Post Posted: Fri Mar 15, 2013 12:39 pm
Yeah adjusted the clutch went good for,about a day then the problem came back
Post Posted: Fri Mar 15, 2013 12:56 pm
dead clutch cable i would say
Post Posted: Fri Mar 15, 2013 1:22 pm
Ok thanks I'll give another cable ago
Post Posted: Fri Mar 15, 2013 1:25 pm
What condition is the clutch fork in? It may be cracked (check around the splined hole )
Post Posted: Fri Mar 15, 2013 6:06 pm
I'll have a check to be sure but I removed the clutch cable an the wire was all split. So replaced it with the one from stock_zuk an seems to be working
Post Posted: Sat Mar 16, 2013 3:50 pm
Could be the throw out bearing is worn and bearing is seized happened to mine not long ago
Users browsing this forum: Google [Bot] and 192 guests
