It is currently Tue Nov 03, 2026 12:17 pm
Vehicle: LWB Sierra & XL7
Post Posted: Sun Mar 10, 2013 11:26 am
I've got a little stock pile of various G16b engine parts and shit bits from later model Vitara and Baleno. I have almost everything but no blocks. 16v heads, intake mani's, valve covers, camshafts, Pistons, con rods, alternators etc.
Ask and I'll see if I have it. $$ open to offers, post extra
'92 Vitara & Camper trailer
Post Posted: Fri Mar 15, 2013 8:54 am
bump.
Vehicle: SJ70
Post Posted: Fri Mar 15, 2013 9:19 am
How much are you chasing for a 16v head with intake manifold?
Post Posted: Fri Mar 15, 2013 12:45 pm
Considering the cost of getting it to you, hows $100.
Vehicle: Getting parts atm
Post Posted: Fri Mar 15, 2013 5:53 pm
Do you have an air intake sensor, starter motor for g16b?
Post Posted: Fri Mar 15, 2013 6:10 pm
Starter motor, a bit grubby, unsure of condition - Yes, $20 + post
Air intake sensor? do you mean airflow meter? - No
Vehicle: Lwb vit, 31's big white fridge
Post Posted: Sun Mar 17, 2013 2:00 pm
Exhaust manifold?
Vehicle: 93 sierra, 1600twincam
Post Posted: Wed Mar 20, 2013 7:30 pm
hi mate, you dont have a mounting bracket for a power steering pump?
Post Posted: Thu Mar 21, 2013 8:00 pm
I have an exhaust manifold for a Baleno.. ;) But not compatible for RWD
No P/S pump bracket.
Vehicle: jimny g13bb, 99 wrx!
Post Posted: Fri Mar 22, 2013 10:22 am
Do you have any camshafts with 11 pickup lugs for the sensor and no dizzy gear? Jimny 1.6 conversion :p
Post Posted: Sat Mar 23, 2013 8:44 pm
I have 2 vitara and 1 baleno cams, it seems that the dist gear can be pressed off.
Post Posted: Mon Mar 25, 2013 8:16 am
Bump!
Vehicle: Sierra
Post Posted: Mon Mar 25, 2013 7:48 pm
Do you have the thermo housing and the right angle outlet
Vehicle: 1990 SWB Vitara
Post Posted: Tue Mar 26, 2013 11:57 am
alternator mate? how much?
Post Posted: Tue Mar 26, 2013 8:37 pm
Wheel studs and nuts? If they are in good nick?
Post Posted: Tue Mar 26, 2013 9:19 pm
Im after a g16b dizzy and brackets for the air cond compressor with power steering pump from a vit jlx ?
Post Posted: Wed Mar 27, 2013 8:26 pm
Thermo housing $10
Alternator $50
Wheel studs are not engine parts
Right angle dist or straight, off the baleno? I presume right angle $80 (later model g16b vitara)
P/s bracket $10 air con is a separate bracket which Im hanging onto in case I decide to put it back on.
Post Posted: Wed Mar 27, 2013 8:42 pm
I have the ps bracket, just need the ac one! :(
Dizzy i think is straight! Opposide side to g16a... What cond? Does it need seals etc as newbies are avail for 170 ish out of te usa.....
Post Posted: Thu Mar 28, 2013 3:25 am
dont have a power steering pump bracket off a 1.6?
Post Posted: Thu Mar 28, 2013 2:37 pm
Condition is used :lol: I took the cap off both and seems ok, the bits dizzy has the seal missing,have check the baleno one, but either way you'd ne better off replacing the seal.
P/S bracket, see 2 posts above. ;)
Post Posted: Fri Mar 29, 2013 12:02 am
pm'ed
Post Posted: Sat Mar 30, 2013 5:17 am
Do u have any coil pack baleno heads? If yes how much for full top end, wiring and computer??
Post Posted: Sat Mar 30, 2013 7:49 am
do you have any coil pack balino cam shafts?
Vehicle: 92 lwb vitara
Post Posted: Sun Apr 07, 2013 10:47 am
do you have the bottom timing gear gear to suit jimny g16bb
Users browsing this forum: No registered users and 13 guests
