It is currently Tue Aug 04, 2026 6:22 am
Post Posted: Fri Mar 15, 2013 1:58 pm
So im trying to wire up a fuckin led bar.
Apparently theres a shitload of ways to do it on Auszookers. But none of them work.
aaaand now the headlight i was using as a trigger has a faint orange glow with no extra stuff hooked up..
Can anyone give me some straight answers?
Post Posted: Fri Mar 15, 2013 2:02 pm
viewtopic.php?f=17&t=4501
Post Posted: Fri Mar 15, 2013 2:15 pm
Doesnt work.
Post Posted: Fri Mar 15, 2013 2:19 pm
then you have issues with how your sierra is wired i would think
Post Posted: Fri Mar 15, 2013 2:24 pm
What would the numbers be on each spot on the relay.
know why my headlight is now fucked?
Post Posted: Fri Mar 15, 2013 2:44 pm
Tried swapping the wires around on the light bar & have the relay & feed off the headlight wired up as per the other 1,00,000 threads :P
Post Posted: Fri Mar 15, 2013 2:50 pm
Ive tried a handful of combos from the threads. All of them dont work in different ways.
The closest i got was it came on with low/high but wouldnt turn off unless you got light off.
But globe still glowing faint.
Post Posted: Fri Mar 15, 2013 3:14 pm
I've always wired it as per want33s post in that good tech thread & never had a drama, pretty much spells it out without having to worry about diagrams.
Post Posted: Fri Mar 15, 2013 3:21 pm
Thats the one that worked the least.
Currently i have it working other than it not turning off when high beams turn off.
30 battery +ve
87 light
86 to ground on plug with an inline switch
85 to drive on plug.
Post Posted: Fri Mar 15, 2013 3:44 pm
Check all ya fuses
Post Posted: Fri Mar 15, 2013 3:46 pm
third or fourth fuse from the left, top row is blown
dont test them with a test light, remove and look at it
The good tech method is spot on, I know it is cause the gazillion headlight looms I make are wired like that (and even the high beam feed for the relay is wired the same) and exactly 100% of them work
Post Posted: Fri Mar 15, 2013 3:54 pm
No blown fuses.
The good tech drawing or the text/quote. Theyre different from my perspective.
I can get it working as it should other than the light bar staying on unless i go back to parkers or flick the switch.
Post Posted: Fri Mar 15, 2013 4:10 pm
The relay seems to stick..
Turn highbeams off and its a few seconds delayed to turn off. Or if i tap it it goes off.
Post Posted: Fri Mar 15, 2013 4:12 pm
Relay sound rooted.
Post Posted: Fri Mar 15, 2013 4:23 pm
"ground" on your diagram is actually 12V and is common to both bulbs. Why you got it connected to drive if the high-beams are actually pass?
If you have it connected up that way in your diagram it should work but I would connect the in cab switch to another 12V source to avoid issues with back feeding and other stuff through the headlight
Post Posted: Fri Mar 15, 2013 4:25 pm
Thats the diagram from good tech by DMAC.
Post Posted: Fri Mar 15, 2013 4:30 pm
you suck more than shep at the electrical strings. :lol:
i miss shep :cry:
Post Posted: Fri Mar 15, 2013 4:48 pm
Replaced all the fuses and the headlight globes and it works by DMAC's diagram. Sweet.
Cheers helpers.
Post Posted: Fri Mar 15, 2013 5:34 pm
For future searching peoples reference, thats whats written on the standard headlight plugs
Vehicle: 85 ' Drover
Post Posted: Mon Mar 18, 2013 9:59 am
Automotive relays have a diagram printed on them very simliar to the above, so just gotta read the diagram, and then connect the numbers.
Users browsing this forum: No registered users and 61 guests
