It is currently Tue Sep 22, 2026 3:48 am
Post new topic Reply to topic  [ 288 posts ]  Go to page Previous  1 ... 6, 7, 8, 9, 10
Post Posted: Sat Oct 27, 2012 9:50 pm
Cheers mate!
Now to sort out this mess for the PCB layout.
Over 150 components to fit on a board that measures 85x100mm. Rum times ahead!! :mrgreen:
Vehicle: Jimny
Post Posted: Mon Dec 17, 2012 10:03 pm
I will admit that I have not read the whole thread, and that a lot of it is way over my head.
But this is all insane! And you are clearly a very switched on guy (the bundy talk gave it away :-p). Kudos for going to the extra effort and not just piecing a megasquirt kit together with diyautotune parts.
Anymore updates?
Post Posted: Fri Mar 15, 2013 1:53 am
Any updates? :D
Post Posted: Fri Mar 15, 2013 10:36 am
Brain has been bleeding out from PhD over-thought and thesis writing. Not fun!
Update wise I've done a heap more on the PCB layout and have been picking Rhinoman's brain quite a bit. Still not happy with my crank trigger interfacing circuit so I have traced out the one's from both a baleno and vitara ECU. Now I just have to figure out one that will work for me.
Home made cam sensor is mounted and works quite well. Temperature sensor it also complete and working. I'll grab some pics.
Sloooooooooooooooow progress as uni has my hands tied pretty tight atm :(
Post Posted: Fri Mar 15, 2013 12:07 pm
you nearly finished yet :D
Post Posted: Fri Mar 15, 2013 7:30 pm
I'm sure uni is just as interesting anyway Dan. 8)
Finished that scooter yet ball? :P
Post Posted: Fri Mar 15, 2013 8:35 pm
nah,
planning a bigger one and collecting parts at the moment 8)
Post Posted: Sat Mar 16, 2013 4:26 pm
Grabbed a few pics of how the cam and temperature sensors turned out.
Cam sensor mounted in sprocket cover
At the moment the cam sensor triggers from the holes in the sprocket but I need to make up a thin steel plate with 1 hole so I can get a single pulse for cylinder synchronization
Turned out fairly neat!
Temperature sensor epoxied into its housing. Just need to drill into the head above the cam to mount it
Post Posted: Sat Mar 16, 2013 9:22 pm
It looks to me like the hole pattern in the sprocket is asymetrical so you should be able to sync up on that.
Post Posted: Sat Mar 16, 2013 9:49 pm
I guess I could give syncing that sprocket up as is. Shouldn't be too much more processor overhead, I hope!
Did you end up receiving my emails with the 60G ECU VR input conditioning circuit I managed to trace and probe out? A few Q in there.
Dan
Post Posted: Sat Mar 16, 2013 11:49 pm
Dan
Yes, I'll have a look at that circuit later
Post Posted: Thu Mar 28, 2013 9:43 pm
The start of something potentially dangerous 8)
I now have a 0-11000RPM hi torque variable speed source thanks to Red89 and gvzookdriver! It works and didn't let all the magic smoke out nor try to bite me!
Post Posted: Fri Apr 12, 2013 10:40 pm
That's crazy....... Watch the fingers :)
Vehicle: Sold zuk got a Bt50
Post Posted: Sat Apr 13, 2013 5:42 pm
:shocked: You even left the blade on the angle grinder
bt50 now but still love the zooks
Post Posted: Mon Jun 03, 2013 4:12 am
Hey Dan, am I right in thinking you're going to use an RHB31?
Post Posted: Mon Jun 03, 2013 9:32 am
Yes sir, That's the plan. Smallest snail I can get my hands on.
Post Posted: Wed Oct 02, 2013 12:37 am
Is it time for an update yet?
Post Posted: Wed Oct 02, 2013 8:05 am
it would be but he is in Japan at the moment i believe
Users browsing this forum: Google [Bot] and 38 guests
