It is currently Tue Nov 03, 2026 8:41 pm
Vehicle: 96 LWB Vit
Post Posted: Fri Mar 22, 2013 9:14 am
Hi All,
Well the time has come to sell off the LWB Vit, Unfortunately the car hasn't been driven since October and before that May - too much other stuff going on....
If someone wants it complete and unregistered for $7500ono provided they come to the party before 29/3.
If not then it will be stripped and parted out, sold off bit by bit and the remaining carcass sent to scrap.
96 Model LWB Vit Manual approx. 290,000k's
Build Thread HERE
Heres the laundry list of bits and pieces I will separate from the vehicle starting 29/3 along with the prices. I can get pics of individual items upon request.
All items are pickup from Acacia Ridge in Brisbane or will ship at your expense after receiving cleared funds.
PM Me for Contact Details
Steel Front Diff(5.12) with Stub Axle conversion, Bearing Carrier & Seal Insert, ARB AirLocker, complete with Compressor & associated Wiring, Diff Drop Brackets, recessed cap bolts and modified 3rd member mount. $1800
5 speed Manual - bearing noise in 3rd gear but still OK. $100
Transfer Case with Reduction Gears Fitted & all new bearings throughout (5000ks Use) - $1000
LWB Vit 96 - Rear Diff complete Hub to Hub with BenT Rear Disc Conversion, (new wheel bearings 3000ks Use) - $600
Calmini 3" Super Articulation Kit - Front Lower Control Arms, Front Springs in Good Condition, Rear Springs sagged and bottom out in LWB, should be OK for SWB, Rear Lower Control Arms, Rear A Arm & Heim Joint, Rear Calmini Shocks, Front Struts Dobinsons Extended Struts - Diff Drop Brackets not in this kit, they go with the steel diff due to mods - $1300
Custom Front Tube Bar suit 2" Body Lift & includes Rydge Ryder 9500lb Winch & Control Box - $500
Custom Rear Bar suit 2" Body Lift - $150
Custom Sliders suit 2" Body Lift - $150
JustCruizin 2" Body Lift Kit - Used - $180
Set of 5 - 15 x 7 Black 'King' Sunraysia Rims (i think they're -10 offset? how would I check) with 31 x 10.5 Silverstone MT-117 Sport - 80% Tread - $1000
Modified Spare Tyre Carrier (Lifted to suit 31" tyres) - $40
Camber Adjustment Bolts Used - $30
Roof Racks & Rails - $50
Roof Basket - $50
Seats - $200
G16B Engine, ECU, wiring loom, starter, clutch (new 3000k's ago) Instrument Cluster - see running in car $600
Extraxtors - $150
Radiator - Good Condition - $100
Factory Clutch Cable - Good Condition - $100
Complete Factory Aircon Setup - Not Cold never gassed by me - $200
Towbar - $50
LWB Fuel Tank & Pump - $200
Complete Power Steering Setup - $300
LowRange Extreme Duty Idler Arm - $100
Front Callipers Rotors & Pads - $200
Post Posted: Fri Mar 22, 2013 9:31 am
would be keen on the idler arm if it does end up getting parted :(
Post Posted: Fri Mar 22, 2013 9:36 am
if u part it out interested in motor
Vehicle: Suzuki
Post Posted: Fri Mar 22, 2013 11:46 am
How much work would it be to make that front tube bar fit my swb vit?
Vehicle: 96 LWB Vit
Post Posted: Fri Mar 22, 2013 11:52 am
Heaps, lwb and swb differ greatly
Post Posted: Fri Mar 22, 2013 7:32 pm
How much for rotors, calipers and spindles?
Vehicle: 96 LWB Vit
Post Posted: Fri Mar 22, 2013 7:42 pm
Make it $260 incl the wheel bearings which were new app. 3000kms ago
Vehicle: 1999 Jimny
Post Posted: Fri Mar 22, 2013 8:18 pm
Will the front diff fir a GV??????
Vehicle: Drover pickup turk
Post Posted: Fri Mar 22, 2013 8:42 pm
Dibs power steering if parted.
I like the tuna here
Vehicle: 96 LWB Vit
Post Posted: Fri Mar 22, 2013 8:53 pm
Not sure, I guess it depends on the model?
It's a steel GV diff from a 2003 v6 Manual.
Post Posted: Fri Mar 22, 2013 9:10 pm
would need to remove the hilux adapter plates, diff drops & pick up a standard late model pinion mount & then make up a RHS CV with flange to suit the stub axle, which is pretty easy.
Vehicle: 96 LWB Vit
Post Posted: Fri Mar 22, 2013 9:23 pm
The hilux pattern plates will be removed so should be good just with a LHS Cv
Vehicle: 1999 Jimny
Post Posted: Sat Mar 23, 2013 6:35 am
Mines a 2000 GV so unless it's been hacked up it should bolt in.
Post Posted: Sat Mar 23, 2013 8:17 am
pinion mount might differ, but you can chase one up easily from a wrecker. you'll need to change the rear diff ratio to suit.
Vehicle: 96 LWB Vit
Post Posted: Sat Mar 23, 2013 8:21 am
Sounds right. The only difference is the stub axle and bearing carrier conversion.
You'll need another LHS cv to use on the RHS.
Also the original vacuum line connection has been blocked off and the internals for that removed. I think that was for auto free wheel hubs or some such nonsense???
Post Posted: Sat Mar 23, 2013 2:50 pm
Depending on how the brass bush has held up i'd be interested in all the lux CV bits... or are you keeping them?
Would also take the idler arm off you if Gus doesn't.
Vehicle: Lwb vit, 31's big white fridge
Post Posted: Sat Mar 23, 2013 5:54 pm
Dibs the sidesteps if it gets parted will pay shipping too.
Pics of the rear bar? Has it been updated since your build thread?
What brand of extractors? O2 sensor any good?
Did you get round to the exhaust? Ill take l that too if it gets parted
Vehicle: 96 LWB Vit
Post Posted: Sat Mar 23, 2013 6:36 pm
No worries,
Will let you know how it all goes when I disassemble.
Vehicle: 96 LWB Vit
Post Posted: Sat Mar 23, 2013 6:45 pm
I think the O2 sensor is OK, but that will go with the EFI & Loom with the engine.
The extractors are just a generic brand, from somewhere in Woollongong i think from memory?
There is a full 2" exhaust system back from that with only 5000k's on it, around 12-18 months old I think. $400 for the whole thing.
I'll get pics of the rear bar tomorrow.
Post Posted: Sat Mar 23, 2013 9:12 pm
Sweet. Thanks.
Ill take the sidesteps
The Exhaust
most probably rear bar too
Vehicle: 96 LWB Vit
Post Posted: Sun Mar 24, 2013 12:21 pm
jimnynutter wrote:
Sweet. Thanks.
The Exhaust
Sliders and Rear Bar have been quite popular, you're on the list but you're first dibs on the exhaust.
Pics of rear bar. Comes with the mudflaps.
Vehicle: Suzuki
Post Posted: Sun Mar 24, 2013 9:49 pm
But The bar will be right to fit I'll just have to cut and weld new mounts to suit swb wouldn't I ?
Vehicle: 96 LWB Vit
Post Posted: Sun Mar 24, 2013 9:59 pm
I suppose it could be modded to suit, never attempted to convert any bar from LWB to SWB so dont know what would be involved.
Vehicle: 92 Vitara JLX project
Post Posted: Fri Mar 29, 2013 7:17 pm
I will take the blocks, also interested in the 3" kit but I have a SWB, trying to find out if It will fit? If you know get back to me otherwise when I have worked it out I will let you know :)
Vehicle: 96 LWB Vit
Post Posted: Fri Mar 29, 2013 8:28 pm
Yep, the 3" Calmini is good for all SE model vits, no mods required between LWB and SWB.
Post Posted: Thu May 09, 2013 10:13 pm
Updates? Still keen on stuff.
Vehicle: 95 Vitara Hardtop
Post Posted: Fri May 17, 2013 8:46 pm
Are the camber bolts still available?
Vehicle: 93 Vitara
Post Posted: Sun May 19, 2013 11:56 am
Have you still got roof rack rails and basket?
Do you know will they fit 93 lwb vitara?
Could you show pictures?
Cheers mate.
Post Posted: Wed May 22, 2013 5:13 pm
Hi just wondering if the engine was still available? Sent you a Pm but no response. Please let me know. Thanks
Post Posted: Fri Jun 07, 2013 10:02 am
has anyone heard from buddy?
Users browsing this forum: No registered users and 21 guests
