It is currently Fri Sep 25, 2026 5:25 pm
Post new topic Reply to topic  [ 50 posts ]  Go to page Previous  1, 2
Post Posted: Tue Mar 26, 2013 9:05 pm
i'm guessing everything was still moist after the blasting you gave it & it's taken a while to hit that dry spell. :P
what i did with mine is always give the probes a good clean with silicone spray & clean up the coil packs so they're spotlessly clean. then around the top lip give it a smear of rubber grease or vasaline to try & stop the water getting in the hole. the other thing i found was positioning the little breather hole so it's sitting hidden under the coil pack inline with where the loom plugs attach so there was less chance of the plug hole becoming moist.
Vehicle: 1997 Vitara 2.0
Post Posted: Tue Mar 26, 2013 9:20 pm
I hope so!
I think the engine cleaning will be left out next time haha
Vehicle: 98 jimny
Post Posted: Thu Mar 28, 2013 7:23 am
I'm thinking I have done the same thing, mine started to sputter after my wash too, I was thinking it was my
Cam sensor again... Hopefully mine just dries out too
Post Posted: Thu Mar 28, 2013 11:47 am
Myn has pretty much gone, only noticed it while taking it for a drive last night and it started jittering a little bit about 5 mins into driving it then it stopped again
Post Posted: Thu Mar 28, 2013 11:48 am
maybe give it a good 48 hours! i warmed the engine up then took out the spark plugs to let the heat evaporate what it could, some one mentioned WD40 to help the evaporation too!
Vehicle: 98 jimny
Post Posted: Thu Mar 28, 2013 6:25 pm
Yeah I got some crc marine water dispersant shit ill give a go
Vehicle: 98 jimny
Post Posted: Sat Mar 30, 2013 6:37 pm
Mines almost gone, only sputters when I am in 2nd and under 2k revs
Vehicle: Jimny 99 2" lift, 31s etc
Post Posted: Sat Mar 30, 2013 7:12 pm
Wd40 works miracles
Post Posted: Wed Apr 03, 2013 1:57 am
Guys, where would you order coil stems from?
I checked Amazon/Ebay and they all say they dont fit my vitara even though it looks identical to what i have in.....
$13
http://www.amazon.com/Beck-Arnley-175-1 ... +coil+boot
$35
http://www.amazon.com/Prestolite-184074 ... +coil+boot
Also, any clue as to why one is over 2x the price of the other??
Vehicle: 98 jimny
Post Posted: Wed Apr 03, 2013 7:10 am
Problem came back again yesterday when I was dropping my daughter off at day care, so after work I had another look under the bonnet and noticed a new oil leak from the tappet cover which I only just replaced the gasket around 2 months ago so I pulled the pcv valve out and it was full of crud, bit of wd40
And compressed air now she is running like a dream
Post Posted: Wed Apr 03, 2013 7:54 pm
good times Armsup Myn is definitely the coil boot/stem thingy as its well and truly made a hole in the side haha
$13
$35
Anybody dare to comment?
Post Posted: Wed Apr 03, 2013 8:04 pm
$13
$35
yess!!
:lol:
Post Posted: Wed Apr 03, 2013 8:13 pm
$13
$35
yess!!
:lol:
HAHA i see...good point, ill take it on board
Post Posted: Wed Apr 03, 2013 8:33 pm
they look the same, i'd grab the cheapies & see how they go.... they look similar to the ones from rockauto :wink:
Post Posted: Wed Apr 03, 2013 8:46 pm
yea thats wat i thought but a price difference like that on 'similar' items usually means the cheaper one has something wrong, that and also it says it doesn't fit a 1997 tracker (as amazon likes)
I got the cheaper one...see how that goes...
Post Posted: Thu May 30, 2013 8:04 am
Bumpety Bump...
I found uber shity rusty shit in and on my spark plugs and wells in my J20 GV (some nuffy maybe forgot to tighten the bolts on the coil packs 6 months ago when I last looked at teh plugs....) when putting new plugs in yesterday.
What is the best way to remove the rust from the wells and is it nessesary to remove the rust??
Dave
Post Posted: Thu May 30, 2013 8:35 am
This is what I mean :p
Vehicle: '94 Sj413, 1.6 baleno convert
Post Posted: Thu May 30, 2013 10:18 am
Definitely clean it out, maybe a small brush head on the end of a drill, the stuff that resembles scotchbrite, cant remember what its called, im sure someone's done it before and can comment!
While we're here, would it be a good idea to put a tiny sliver of RTV around the tops of the wells to prevent water and crud getting in there in the first place?
Maybe even some grease if you're removing them frequently.
Post Posted: Thu May 30, 2013 11:20 am
i used rubber grease around the seal & a coat of silicone spray on the stem. the top section has a nice seal on it & there is a built in breather tube in the rubber probe so you can't seal it up 100%
looks like even after all those months there is still moisture in the plug wells, i'm guessing it got a good pressure clean after the mud racing incident?
Post Posted: Thu May 30, 2013 12:47 pm
:lol:
Probably was Atari and also not helped by the 4 months sitting on the side of the road not being started that might of not contributed to it :D
