It is currently Tue Nov 03, 2026 9:06 am
Post Posted: Tue Apr 02, 2013 6:01 pm
What are the pro's and con's of rear disconnects why have them what's the bennifets ????
Post Posted: Tue Apr 02, 2013 6:12 pm
Front digs.
Flat towing.
Adds 1" to the back of the transfer so, mods may need to be done. Cut a notch in the floor.
You wanted one before you knew what it was for? :lol:
viewtopic.php?f=8&t=39967
Post Posted: Tue Apr 02, 2013 6:28 pm
I know what it does but wanted to know wether or not it is a good idea
Post Posted: Tue Apr 02, 2013 6:33 pm
Do YOU think its a good idea?
Post Posted: Tue Apr 02, 2013 6:36 pm
lol :lol:
you'll want cutting brakes to make the most of it.
Post Posted: Tue Apr 02, 2013 6:41 pm
I think it's a good idea
Post Posted: Tue Apr 02, 2013 6:45 pm
Then buy it.
Post Posted: Tue Apr 02, 2013 6:50 pm
I just wanted to know about it from people that have it
Post Posted: Tue Apr 02, 2013 6:57 pm
If it gets shaky later and if it's hard to lock it back in and stuff like that
Post Posted: Tue Apr 02, 2013 7:07 pm
are you plannin cuttin brakes??
individual line locks?
or do you have a really good hand brake??
do you have a locker in the rear?
Post Posted: Tue Apr 02, 2013 7:15 pm
Not really worth it on a daily driver, weekend wheeler.
Post Posted: Tue Apr 02, 2013 7:50 pm
I have one. I don't think it's worth it.
Post Posted: Tue Apr 02, 2013 7:55 pm
The TT unit DDs well :)
In the mud I think there worthless, not worth the $400.
In technical rock tho, absolutely gold when you figure out the right time to use it. I currently only have drum handbrake but am upgrading to disk rear and line locks. Hoping it betters the dig operation again.
But I really think the person driving makes it worth it or not.
PS: not a shot at Gwagen.
Post Posted: Tue Apr 02, 2013 8:02 pm
Ahh ok thanks that helps heaps I am doing rear disk brake soon with the electronic line locker on the rear and move the transfer hand brake so I can do rear disconnect
Post Posted: Tue Apr 02, 2013 8:23 pm
It can also be used for when the front end is trying to climb a large step up, you flick the lever for front wheel drive, you then dont have the rear trying to push you into the ledge whilst the front end is trying to climb vertically. Again this is only useful when you have a near 90 degree approach angle like on a buggy and not a bullbar, bumpers or shackles sticking out the front.
Post Posted: Tue Apr 02, 2013 8:24 pm
Can be used to pack your own rocks :lol:
Post Posted: Wed Apr 03, 2013 9:15 am
Obviously I'm in Melbourne so we don't have much technical rock, and I'm more than aware that digs/burns do work. I've found that with 29˚ of steering angle, and even with my Krawlers, I don't really have enough traction to get the front to do much. With more steering angle and maybe some more weight on the front end it might be more effective, but it's a real lucky dip as to whether it's going to work or not. Wne it's worked to say, jockey the front of the car over 12" or so to get the right line, it's been great, but more often than not, you unload drive, shuffle around with the lever, line lock the back end, give it full lock, punch it, and nothing happens, so it's unload drive, shuffle the lever back in, and drive it like everyone else.
I was fully on board with the theory of how useful it would be, it just didn't pan out that way, for my use. With stickies, 40˚of steering and dry rock, I can see it being really cool. don't have any of those things.
We have two cars in the club with them, we've both had the same result.
Post Posted: Wed Apr 03, 2013 8:04 pm
Hell it would probably be more effective to have a set of cutting brakes.
Atleast then when your on 'non sticky surfaces' it could lock out one wheel and use the other 3 wheels to spin the car around.
EDIT: this wouldn't work with a spool and I'm not sure how it would go with an auto locker. So you might have to run an open or airlocking diff for the sake of having cutting brakes. And as we all know cutting brakes aint a locker.
Post Posted: Wed Apr 03, 2013 8:09 pm
It would work with an auto locker.
Post Posted: Wed Apr 03, 2013 8:14 pm
Proof?
Post Posted: Wed Apr 03, 2013 8:17 pm
They lock with drive. No drive, they ratchet.
Post Posted: Thu Apr 04, 2013 8:50 am
Yeah, true, but that's the opposite to what I said above.
Like locking off a back left wheel and using the other 3 to try spin around it with cutting brakes...
So it would have power being put through it...
Post Posted: Thu Apr 04, 2013 8:53 am
Thought you meant with rear disconnect. I don't see the point without a disconnect...
Users browsing this forum: No registered users and 73 guests
