It is currently Sun Nov 01, 2026 3:17 pm
Post Posted: Fri Apr 05, 2013 3:17 pm
hay guys, i have a 94 lwd vitara and im just after some ideas were you have mounted your uhf if you dont have a bulbar? i no you can get them brackets that come out the side or front of your bonnet but cant see many good spots to actually mount it, my old sierra bonnet was a different design to the vit and was easier to mount, pics of were you mounted your uhf would be great
cheers scott
Post Posted: Fri Apr 05, 2013 3:37 pm
Mine have been mounted in the spare wheel bracket, sure it's not the best position for reception but I'm not in the desert & need 1 billion kms range, it's well protected + it looks like an r/c car.
Post Posted: Fri Apr 05, 2013 5:35 pm
I've looked over my Zook looking for a spot to mount mine, and come to the same conclusion, spare wheel bracket is the go!
Post Posted: Fri Apr 05, 2013 5:47 pm
I'm in the same dilemma, I guess mines going there too. Now just need something to mount spots to
Vehicle: Jimny 2009 vvt JIL
Post Posted: Fri Apr 05, 2013 5:50 pm
here is mine. used a tie down strap to fit it to the rear spare wheel. the cable goes through underneath rhe near door to my inside of my car.
I glued the cable with mirror silicone. just make sure you make sure the contact points are very good to the contacts of the antenna's connection that is gona sit on the back door so it dont vibrate loose like on gravel road.
hope this help.
mine is a dualband antenna thats why it is so short.
Vehicle: 99 Dirty Green Jimny
Post Posted: Sat Apr 06, 2013 11:52 am
I just fabicated a little S bracket that piggybacks onto a bolt and thread already underneat
Favourite part is that it'doesnt obstruct any vision where it sits, and don't have an ugly antenna in the middle of any videos/photos from inside the cabin. Also sits right above the grommet through the firewall
Post Posted: Sat Apr 06, 2013 2:14 pm
thanks for the idears guys any one actually mounted one on the front of a vitara that they have a pic of? id rather have it at the front of the car as i dont really want to mount it on the spare wheel.
cheers scott
Post Posted: Sat Apr 06, 2013 2:44 pm
I just used a bit of flatbar straight out the side of the raised section at the back of the bonnet mate. Picked up an existing bolt hole that was already there plus used a couple of extra tek screws on the top of the guard (would use rivnuts/bolts these days :lol:) to stop it from swivelling.
Worked perfectly, never moved even with bashing the aerial on overgrown tracks.
Post Posted: Sun Apr 07, 2013 9:04 pm
i like that idear as it just looks better at the front of the car i reckon, you dont have a close up of the bracket do you?
cheers scott
Post Posted: Mon Apr 08, 2013 5:58 am
I have seen people buy those $30 Super Cheap Auto Spot light brackets that mount over your number plate and use that ??
Users browsing this forum: Google [Bot] and 258 guests
