It is currently Thu Sep 24, 2026 1:08 am
Post new topic Reply to topic  [ 142 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
Vehicle: 98 jimny
Post Posted: Wed Apr 03, 2013 8:22 am
Missus wanted some shelves for the baby's room and what she was looking at cost around 600-800 so built this instead
I think we need another tho, cost under 200 to make buying everything new
Vehicle: 98 jimny
Post Posted: Wed Apr 03, 2013 3:47 pm
And something else I knocked up today
The start
Cutting the tin to size
And with 5 screws left in the last bit of tin
Pissed down with rain untill I put all the tools away
Got somewhere to store the jimny now, might inclose it yet too, still have 17 sheets of tin left
Post Posted: Wed Apr 03, 2013 8:06 pm
Holy long spanning rafters batman :shocked:
How did you get that thru council?
Have you heard about the timber framing code? They give you span tables for stuff like that, 140 x 35 wont span 6metres :wink:
Just hope it stays up long enough so you can reinforce it some way. :?
Oh, and cutting roofing iron with an angle grinder is instant dismissal :roll:
[/end rant]
Vehicle: 98 jimny
Post Posted: Wed Apr 03, 2013 9:37 pm
Lol scared you didn't i, she isn't finshied yet, got acro props under it for the time being untill I finish welding the I beams up and I'm going to run a block and tackle off it or lifting my pressure cleaner on and off the trailer/ truck then to to top it all off it's getting a coat of Jaspa cool roof so I don't break a sweat when working under it
And the angle grinding was safe, clamped the sheets together AND used the guard on it :wink: and as for instant dismissal the other half has already said she is moving my stuff out of the house and into the shed lol
Vehicle: 91 sierra, g16b,lift,30's
Post Posted: Sat Apr 06, 2013 7:42 pm
I was just about to say that span is pretty epic. It looks like 90x35 in the picture.
Post Posted: Sat Apr 06, 2013 11:13 pm
not sure if this is the correct spot to play this, but this is what we build at work. I didnt build this particular engine but have build them before, i just set this one up for dyno. Dont remember the exact power figure but it was rather impressive, When you hear me say "that is good" at the start im talking about how quiet the engine is. I walked in at idle without ear protection and could talk to the person next to me!
engine is a QSK50 MCRS (Modular Common Rail System) V16 50L
Post Posted: Sun Apr 07, 2013 12:47 am
V16 -50L...[does the 50L designate capacity- or is it a model number?]
YEP! right thread as I doubt very much it came out of a car
Vehicle: 2003 V6 Grand Vitara (SQ625)
Post Posted: Sun Apr 07, 2013 1:44 am
Even if it's not out of a car - It's an engine and shouldn't be in this post :cry:
http://www.auszookers.com/forum/viewtopic.php?t=36934
Post Posted: Sun Apr 07, 2013 2:07 am
As I am renting in my current house, the only way to use my projector was a stand as i wasn't allowed to mount it too the roof/ceiling but the screen was plausible. Pretty solid base i have made so far. It is still in the making, so bare with me for the final piece... :D
Drilling and cutting in my backyard at quarter to 1 in the morning, I don't think the neighbors are happy with me :lol: but i don't have a shed :(
Post Posted: Sun Apr 07, 2013 3:57 am
Put it up temporary to see what it would look like... Still lots of work to be done e.g sanding, varnish, gloss etc :D
Post Posted: Sun Apr 07, 2013 5:37 am
Needs a few minor adjustments, but I'm pretty happy so far :D
Vehicle: 98 jimny
Post Posted: Sun Apr 07, 2013 7:13 am
That's a tiny projector but looks like you get a good clear picture from it but, what size screen can you get?
Post Posted: Sun Apr 07, 2013 9:30 am
Yeah it does, eg: qsk60 is a 60 litre. Same for the qsk50. I thought, there isn't an engine thread and this something that I build, I couldn't find a thread about stuff we do at work. Can remove it if needed.
Post Posted: Sun Apr 07, 2013 2:55 pm
The screen i am using is only 1.5m wide and i have this set to a screen ratio of 4:3. The standard for HDMI is 16:9 which i cannot use as i would need a 2.5m screen. That would be great but the wall is not wide enough :cry:
Even on this ratio and distance, i had a bit of trouble adjusting it as the projector only has a limited amount of built-in settings, so this may have to do for now. Maybe see if i can buy some sort of ext adjuster.. I'll figure something out hopefully :P and size doesn't matter :lol:
Vehicle: 98 jimny
Post Posted: Sun Apr 07, 2013 4:05 pm
I think I must be over compensating for something as this is my projector
Image and it is about 20kgs
Post Posted: Sun Apr 07, 2013 5:07 pm
What brand is it??
Post Posted: Sun Apr 07, 2013 6:52 pm
That is a big projector!
Like those boys that drive around in their f100's and green utes :lol:
Mine does the job quite well and is easy to move around - It's about 4kilos :P
Rusho wrote:
What brand is it??
Brand is 3D Imaging - Full review here http://imaging-3d.com/products/hd-7500/index.html#
Post Posted: Sun Apr 07, 2013 7:00 pm
I'm a bit concerned that with it being so tall, even with the base as big as you made it- it might be prone to tipping over if knocked.
How about getting a bag of lead shot from a gunshop and pouring the loose shot inside the stand to give it some more stability.
There are a couple of gunshops in the northern suburbs- hunters den in joondalup, and shooters shed in wangara, both should have lead shot in tubs of 10kg or so.
Wouldnt matter what size shot for what you are doing.
Couldnt say how much shot costs these days, I only load solid slugs that I cast out of wheel weights and scrap lead.
Whatever the shot cost- it wil be heaps cheaper than buying new projector.
stephen
Post Posted: Sun Apr 07, 2013 7:21 pm
stephen
That was the first thing i thought of when making this. It is stable as and doesn't even pick up the vibrations from the subwoofer in the room. Also it wouldn't be possible to tip forward as it would just rest onto the back of the couch. Pretty stable with not falling side-ways or back as the base goes under the couch. But if anything gets unstable, i have some 5kg weights lying around :)
Also what isn't shown, are are the 4 big screws i have going up through the walls of the stand from the base :D
Post Posted: Sun Apr 07, 2013 7:27 pm
Looks good- you have it pretty well trapped in place.
No need for lead after all!
Stephen
Post Posted: Fri May 10, 2013 5:45 pm
Still working on my stand and found a better fab bench :P
Post Posted: Sat May 11, 2013 2:58 am
Progress so far at 1:27am :P
Post Posted: Sun May 12, 2013 7:56 pm
Added a bit more to the stand. Only about 50% done and wiring is not yet complete
Post Posted: Sun May 12, 2013 7:58 pm
The bricks out the back needed re-laying as the owner didn't concrete the edges, so i fixed them up and started on a little path towards the clothesline.
Not bad for someone who had never laid bricks before. :)
Post Posted: Thu May 16, 2013 11:17 pm
Simple job, but came out so well!
The 5 dollar wall clock we bought from Ikea 10 years ago finally died, so I built the missus another one out of some recycled timber I scored at work, and about 30 odd stainless/mild nuts. Came out friggen awesome for about an hours worth of work.
Great success
Screw you old clock!
Oh yeah, the parts that touch the wall have stick-on cork protectors so it doesnt have scabby wood touching the walls.
Love it when a passing idea comes together like this so well!
MY BUILD THREAD HERE!!!!!
Post Posted: Thu May 16, 2013 11:24 pm
very creative :wink:
Post Posted: Fri May 17, 2013 1:36 am
Cheers Pete,
It's about as creative as I get.
Post Posted: Fri May 17, 2013 4:47 am
That's amazing! Looks real good :shocked:
Post Posted: Fri May 17, 2013 6:02 pm
Smells awesome when you walk past it too, love the woody/oily/stainey smell!
Post Posted: Fri May 17, 2013 7:32 pm
Very nice scales.
What's the weight like?
Users browsing this forum: No registered users and 28 guests
