It is currently Sun Nov 01, 2026 12:24 am
Post Posted: Mon Apr 08, 2013 10:50 am
How wide are they and how long compards to standard and Mazda springs and whe re is the diff locator Will it be fine or do I need to change it? Will it move the diff forward much or backwards?
Post Posted: Mon Apr 08, 2013 10:51 am
Also what model cj? ?
Post Posted: Mon Apr 08, 2013 10:54 am
they are about 100mm longer than efs lifted rears.
they are 50mm wide like sierra springs.
cj7 fronts is what your after.
it will move your diff about 50mm back.
Post Posted: Mon Apr 08, 2013 6:05 pm
Ahh ok thanks :)
What is the longest spring that you can put into a swb Sierra ? Is it jeep cj or yj or Mazda ? Or any other ?
Post Posted: Mon Apr 08, 2013 6:24 pm
None of them bolt straight in. So it could be any spring
Post Posted: Mon Apr 08, 2013 6:28 pm
I don't mind making some mounts and stuff I was thinking of putting mq patrol front or rears in mine they are really long I am going to runn cj springs in front but want something longer in rear
Post Posted: Mon Apr 08, 2013 6:29 pm
What are longer cj or yj ?
Post Posted: Mon Apr 08, 2013 6:43 pm
They are the same if i remember.
YJ are wider/thicker though was the difference.
Post Posted: Mon Apr 08, 2013 6:49 pm
Ahh ok hmmm is it better and easier to just go jeep springs all round ?
Post Posted: Mon Apr 08, 2013 7:06 pm
Can we list up some lengths please
Total length. Big eye to centre bolt
Sierra front
Sierra rear
Mazda
Jeep
MQ
Post Posted: Mon Apr 08, 2013 7:14 pm
Which ones?
CJ, YJ, TJ, JK, XJ?
Post Posted: Mon Apr 08, 2013 7:22 pm
http://www.computermedicsfranchises.com ... prings.png
Post Posted: Mon Apr 08, 2013 7:27 pm
Jeep cj front 50mm wide 560mm to locator 1120mm long
Rear 62mm wide 573mm to locator. 1146mm long
Post Posted: Mon Apr 08, 2013 7:30 pm
Jeep yj front and rear
62mm wide
576mm to locator
1152mm. Long
Post Posted: Mon Apr 08, 2013 7:39 pm
From the link
Cj fronts 50mm wide. 1120 long. 560 to bolt
Post Posted: Mon Apr 08, 2013 8:09 pm
Had no luck finding mq patrol lengths but I know they are longer on 1 side by quite abit like 4 or 6"
Post Posted: Mon Apr 08, 2013 8:38 pm
This is a start.
http://www.generalspringkc.com/Leaf_Spr ... s/1947.htm
This one gives you everything but the spring length :roll: But you can compare the pring rate between the MQ and the Sierras
http://www.drivetrain.com/parts_catalog ... PartNumber
This may come in handy for someone later on.
http://www.therangerstation.com/tech_li ... ngrate.htm
Post Posted: Tue Apr 09, 2013 7:33 am
I had mq springs in my sierra on the rear. They werent that long. And way too stiff
Post Posted: Tue Apr 09, 2013 9:53 am
the way i figure it, rear sierra are around 100mm longer than front sierra springs.
so CJ being around 100mm longer will be equivalent to RUF.
and we have all seen how much improovment is in a RUF setup.
Post Posted: Tue Apr 09, 2013 10:28 am
something to consider tanshi is that theres next to no weight in the rear - the reason the front benefits so much from RUF is that the rear leaves have less rate than the fronts.
Post Posted: Tue Apr 09, 2013 10:42 am
true, but the benifit will be more than normal two inch lifted rears.
plus if you play with spring rate like you should any way you will get even more benifit
Post Posted: Tue Apr 09, 2013 3:45 pm
mazda/corolla springs are in other threads, "longer springs"
Users browsing this forum: Google [Bot] and 152 guests
