It is currently Fri Sep 25, 2026 9:23 am
Board index » Shift It And Find It » Business Directory
Post Posted: Sun Oct 02, 2011 7:23 am
What's New? Canvas Seat Covers to fit WT
Welcome to the Bulldog Trimming thread. I own a pretty little SJ40 Tray Back called KT, so named because it's very orange, but only little, hence "Kumquat Taxi". There's some pics of KT lower in the thread, but you're probably here to see what Bulldog Trimming offers in the way of products and services. Apart from the full range of trimming services, I make a range of soft top options for standard tub Sierra's which I can mail anywhere. I can cater for other models, or custom tub Sierra's, but I would need the vehicle in my workshop.
Custom work is not a problem, and any of the products listed and pictured below can be changed to suit your preferences. All work is carried out by me, and only premium products are used. I'm always looking for ways to improve on what I do, so feedback is always welcome. Thanks for looking, scroll down the next post for products and prices.
I'm making a set which leaves the headrest uncovered also. Cost is $220 per pair, including postage.
Post Posted: Fri Nov 25, 2011 11:16 pm
I'm pleased to say that I now have available Bikini Tops and Fastbacks. At this stage the Bikini will be either stand alone for $220, or Fastback ready for $240. The Fastback is detachable, and on it's own is $380. As a Bikini/Fastback combo the cost is $600. Naturally postage is additional.
I use premium Black on Black Tonneau material and unless requested the windows are tinted. Windows are HF Welded in and press studs are Stainless Steel. Next up is some LWB options, and shade cloth Bikini Tops. Please PM if you're interested
Post Posted: Thu Dec 15, 2011 8:44 am
SWB Full tops are now ready to order! As with all our tops, only premium materials are used, windows are tinted and welded in. I use templates to cut pieces, but every top is checked on the jig body for fit and function before it's posted. Cost for these tops is $720 plus postage.
Post Posted: Wed Feb 08, 2012 12:34 pm
Here is my Bikini/Windjammer/Tonneau combination. The windjammer is attached at the top using stainless steel rod through which the straps for the Bikini pass. The tinted window can be opened with the two zip slides and falls out of view so strapping up and losing visibility isn't a problem. At the bottom of the Windjammer stainless steel is enclosed in a stitched pocket. Tonneau is attached with a zip, and covered with a velcroed flap. There are two straps going through supplied brackets which enable the Windjammer and Tonneau to be tensioned giving a cleaner look and less flapping. Price for this package as pictured is $800.
Post Posted: Sun Feb 26, 2012 4:19 pm
SWB Full tops are now ready to order! As with all our tops, only premium materials are used, windows are tinted and welded in. I use templates to cut pieces, but every top is checked on the jig body for fit and function before it's posted. Cost for these tops is $600 plus postage.
www.bulldogtrimming.com
Post Posted: Thu Apr 11, 2013 7:56 am
Users browsing this forum: No registered users and 1 guest
