It is currently Tue Nov 03, 2026 3:53 am
Vehicle: 2018 DMAX
Post Posted: Mon Apr 01, 2013 2:39 pm
Pick up only 4114/Kingston. More to add as i find it. Some prices negotiable.
Early vitara G16b. Unknown kms. Fresh timing belt/water pump. Small amount of smoke on start if it has sat for awhile. Heavier oil seemed to fix this... Other wise it was very strong and never let me down. Is currently mated to a Sierra box, so would suit use in a sierra(unless you have the studs to fit it in a vitara).. $400
5x Federal Couragia 235/75R15 on black Dynamic's. 15x7 -13. 1 new, two around 10mm tread, 2x around 9mm tread. Normal tread damage from 4wding. $450 SOLD
4x Kuhmo 798 AT 215/70R15. Approx 10mm tread. Rims look like ROH Tek's or something similar, appear to be close to standard offset. The spare that came with this set is a 205/75 on stock rim, don't take it if you don't want it. $300
2x WT jack shafts. No play in unis, $30 each.
1x WT front drive shaft, no play in unis. $40
1x G16b extractors, no flange. Bashed to fit into a sierra. Surface rust. $70
VL engine mount $10
3x transfer mounts $10
G16b Denso coil/ignitor, removed from running motor. $40
Complete g13b dizzy. $30
G16b dizzy bare. $30
Narrow body starter G16b . $50 SOLD
4pin 22 spline center. $30
12x hub bolts with con washers. $20
1LTR switch, 2xWT flanges. No rear flange. Was rebuilt at some point, it drove well
but condition is unknown. $150
ABS plastic flares to suit Sierra, they covered 31's on 15x7 - 13's. $150 SOLD
Good fuel tank with ODA guard, tank has drain plug. $100 Tank is gone, bash guard only $50
Alloy bar, unknown brand. Damage as pictured. Bar/indicators only. $75
No pictures for this stuff
1x NT 1.3 transfer/transfer handbrake in GC, is fitted to my daily driver and works very well. $200
Baleno G16B. 150, 000. Head has been recoed recently. Sump setup for sierra. Will be sold without manifolds/dizzy. Right angle drive distributor with vitara cam, uses vitara dizzy. Valve clearances need doing. Fresh head gasket. $550
2" OME comfort rears. 3 leafs in one pack, 4 in the other. Was used in the front of a sierra with RUF. $75
2" Spring pack. Custom mains(around 1060mm long from memory, longer than EFS rears), with fillers from assorted packs. 4 leafs + main in each pack. Enough here to mix and match into a nice set of rears. $75
Loneranger long range tank for sierra. 70ltr, some small dents. Required removal of old rear mounts from chassis when fitted to a NT. $150
1.3 sierra gearbox. Runs quite, syncros on 2nd/4th are getting old. $75
1.3 sierra gearbox. Input bearing is noisy. Shifts really well. $75
Some prices negotiable!
Post Posted: Mon Apr 01, 2013 4:00 pm
Pm sent about vl mounts and jack shaft
Vehicle: 1995 SWB Sierra TinTop
Post Posted: Mon Apr 01, 2013 7:01 pm
PM'd about flares :)
Vehicle: 89 w/t sierra
Post Posted: Thu Apr 04, 2013 9:00 am
Would the fuel tank be too big to ship down to Melbourne? Happy to pay freight
Vehicle: 2018 DMAX
Post Posted: Thu Apr 04, 2013 9:06 pm
Ill take some measurements and get a quote. What postcode?
Post Posted: Fri Apr 05, 2013 5:59 am
Pm sent
Post Posted: Fri Apr 05, 2013 2:31 pm
do u still have the bar?
Vehicle: 2018 DMAX
Post Posted: Fri Apr 05, 2013 2:38 pm
Still got it
Vehicle: Daisy
Post Posted: Fri Apr 05, 2013 4:16 pm
Is that starter in good order?
If so I'll take it, the one that was on my engine (being from a baleno) isn't the freaking same :(
Do you want to post or prefer pickup, can send you the $ and pickup in a few weeks if that works?
Vehicle: 2018 DMAX
Post Posted: Fri Apr 05, 2013 5:25 pm
Starter was pulled from a working motor, I had issues with it at one point but a good internal clean has given me 6months of trouble free starting. I would prefer pickup, willing to hold it if its payed for.
Vehicle: Daisy
Post Posted: Sun Apr 07, 2013 6:42 am
Pm me your details and ill send through the dosh, if you also let me know pickup addy ill work out when I can get there and let you know.
Vehicle: 2018 DMAX
Post Posted: Thu Apr 11, 2013 5:23 pm
Bump and new stuff down the bottom of the post.
Vehicle: Jx sierra
Post Posted: Thu Apr 18, 2013 11:36 am
Pmed about springs
Post Posted: Thu Apr 18, 2013 9:03 pm
Where abouts in Brizzy are you? Might try and organise some one to pick up the transfer case and fuel tank bash plate if you still have them
Vehicle: 91 swb vit 5"lift 31's.
Post Posted: Thu Apr 18, 2013 9:32 pm
you thinking of selling those spotlights by any chance??
Vehicle: 1988.5 tin top
Post Posted: Fri Apr 19, 2013 11:41 am
Messaged
Vehicle: 2018 DMAX
Post Posted: Sun Apr 21, 2013 11:29 am
Been away for a few days, just replying to everyone's PM's..
holden26 im at Kingston. transfer and guard still here. Which transfer did you want?
Users browsing this forum: Google Adsense [Bot] and 15 guests
