It is currently Thu Oct 29, 2026 5:52 pm
Vehicle: 89 soft top
Post Posted: Thu Apr 25, 2013 7:43 pm
Gday all just wondering if anyone can give me advice or a link on replacing the throw out bearing in my 89 1.3 sierra...and I have been searching for ages on this forum
Post Posted: Thu Apr 25, 2013 8:15 pm
What do you want to know?
Pull either the engine or gearbox out to get to it. Pull the old one off put the new on. Put the little clips on then put the engine/gearbox back in.
Simple job, just a lot of stuffing around to get to it.
Post Posted: Thu Apr 25, 2013 8:27 pm
Cheers so don't need any special tools of pullers ? Also whats the better option pull the donk or the box
Vehicle: 85 ' Drover
Post Posted: Thu Apr 25, 2013 8:35 pm
http://www.suzukiinfo.com/
grab a manual and follow the instructions.
Essentially just take it appart untill you can get to the bearing, repalce bearing (noting how the old one was attached), and do everything in the reverse order.
Post Posted: Thu Apr 25, 2013 10:05 pm
Its all pretty easy mate. I just replaced the clutch in my sierra.
Front driveshaft out, jackshaft out, remove centre section of exhaust, remove starter, remove brace from between chassis rails, remove shifter, undo gearbox mount, unbolt gearbox from block.
When removing the gearbox you need to rotate the bottom towards the drivers side to clear the crossmember. Its pretty light you can remove it with 2 hands. The throwout bearing just sits on the clutch arm held in place by a pin on one side.
Post Posted: Fri Apr 26, 2013 10:51 am
Beauty cheers guys
Users browsing this forum: Google [Bot] and 223 guests
