It is currently Fri Nov 13, 2026 1:30 pm
Vehicle: 1997 Vitara 2.0
Post Posted: Thu Apr 25, 2013 7:29 pm
Guys,
I was messing around with the vit to tighten up all the nuts and bolts.... and ironically i have stupidly misplaced the lower bolts and nuts that attach the rear shocks! can someone please give me the dimensions of what i need to buy???
If one of you guys know I would really REeeaaally appreciate the reply tonight/tomorrow morning as I was planning to go for a cheeky trip brunswick/collie this saturday morning! would be gutted if i didn't get to go!
STUPID ME!
cheers
Col
Post Posted: Thu Apr 25, 2013 7:50 pm
For just a one day trip, any bolt that is long enough, with a matching nut.
Too loose may rattle.
Measure hole bolt goes through, to get correct bolt thickness.
Get a bolt long enough to go thru shock and have thread sticking out for nut.
Vehicle: SJ80, SE416
Post Posted: Thu Apr 25, 2013 8:26 pm
High tensile M12 60mm or 65mm long with spring washer under the nut.
Actual bolt looks like M12 fine 60mm with tapered thread and HD spring washer. See pics below.
Post Posted: Thu Apr 25, 2013 8:40 pm
Guys Thanks so much!
So nothing 'special' just a high tensile Bolt, m12, 60-65mm.
Thanks once more!
Post Posted: Thu Apr 25, 2013 9:40 pm
Never seen a bolt with a tapered thread - pipe fittings yes - bolts nope.
Post Posted: Thu Apr 25, 2013 9:44 pm
Ditto. The onlt thing that is 'special' about these bolts is that they have an extra long shank section to prevent the thread from eating the bushes.
Post Posted: Fri Apr 26, 2013 2:08 am
thread wont eat the bush when theres a crush tube in them.
Post Posted: Fri Apr 26, 2013 2:28 am
To be quite honest, I've been curious about the length of the bolt, but as losfer says - the thread won't eat the bush if there's a crush sleeve. My GV has long bolts in that position, and so does my Pajero iO.
Post Posted: Fri Apr 26, 2013 2:40 am
Ath=0.5πd0L0. / d0=(d2+d3)/2
Post Posted: Fri Apr 26, 2013 8:46 am
Sorry guys - didn't mean tapered as ones used on pipe fittings etc, meant tapered just that it has the last 3 or so millimetres of thread rounded off at the end to help locate the bolt through the hole - as seen in the pics.
Excuse my grammar but what would you call this?
Users browsing this forum: No registered users and 20 guests
