It is currently Tue Aug 04, 2026 12:13 am
Vehicle: Coil Sierra
Post Posted: Wed Apr 24, 2013 1:55 pm
Both these starters are listed for the sierra. One mentions it suits (some).
One is alot bigger than the other, here are the specs
http://www.pinpoint.aea.com.au/Guest_pc ... bl=Starter
Need the one to suit a g13ba.
Any help would be great.
Post Posted: Wed Apr 24, 2013 2:49 pm
the one in the second pic suits a swift or fwd configured gearbox with the offset holes on the nosecone of the starter.
Vehicle: tin top sj70
Post Posted: Wed Apr 24, 2013 3:30 pm
I bought a starter moter a month ago and the guy gave me the second one which does not fit
Post Posted: Wed Apr 24, 2013 4:15 pm
there are 2 versions though... there's the stock sized one and there's a smaller aftermarket version which is better for people running g16 blocks.
Post Posted: Wed Apr 24, 2013 4:37 pm
Can i fit the fatter version of the top one to my 1.3? I pulled it out of a very early jimny
Post Posted: Fri Apr 26, 2013 2:00 am
yes you can , the fatter one is just a direct drive off the armature , the thinner one has a little "gearbox" in it (reduction drive) the thinner one produces more torque , the fatter one works fine and has done in many a sierra.
Post Posted: Sat Apr 27, 2013 10:03 pm
Thanks
Post Posted: Wed May 01, 2013 5:33 pm
Just fitted the g13bb jimny starter motor, was exactly the same size and shape as the one i pulled out.
Repacement one sounds a little different than the old one, do they need lining up perfect when fitting it or just line bolts up and tighten?
Vehicle: LWB Sierra & XL7
Post Posted: Wed May 01, 2013 7:17 pm
mine turned out to be the same as my Vitara
viewtopic.php?f=5&t=36170&hilit=starter+motor
'92 Vitara & Camper trailer
Users browsing this forum: No registered users and 46 guests
