Joined: Wed May 25, 2011 12:14 am Posts: 111 Location: wollongong
Posted: Mon Apr 29, 2013 7:16 pm
Hi guys I need to fit a longer pitman arm to my vitara steering box (fitted in my Sierra). What type can I use? I remember something about Toyota tarago is that right? Cheers Rob
Lowrange used to sell a dropped pitman arm suitable for a vitara steering box in a sierra. It was about a 60mm drop from memory and was approximately 17mm longer than a standard vitara pitman arm. I think it is now discontinued/unavailable.
It was a bit of a double edged sword though - with moderate lift height it really put the drag link too low and the extra length puts the tie rod and drag link very close together.
Do you have more info on your setup? I have no problems getting full lock with a vitara pitman arm and sierra axles.
Users browsing this forum: No registered users and 253 guests
