It is currently Fri Oct 16, 2026 10:01 am
Vehicle: Jimny
Post Posted: Wed May 01, 2013 10:03 am
Quick question, but does anyone have extended front bump stops? My 29" tyre rub a lot when hitting big bumps. It's ok for normal duty / light offroad.
Thanks
Vehicle: LWB Sierra & XL7
Post Posted: Wed May 01, 2013 7:07 pm
Quick answer. Yes
viewtopic.php?f=14&t=35409&hilit=bumpstops
'92 Vitara & Camper trailer
Vehicle: Jimny
Post Posted: Wed May 01, 2013 7:37 pm
Thanks, but it's a coily jimny...
Vehicle: 2004 Jimny 1.6
Post Posted: Wed May 01, 2013 7:39 pm
Aren't all jimnys?
Vehicle: 93 Vitara -itty bitty lift
Post Posted: Wed May 01, 2013 7:51 pm
you can use a rubber mallet or hockey puck as a check bump stop extension,
this is a jeep site but you get the idea
http://jeep-xj.info/HowtoBumpstops.htm
Vehicle: Jimny
Post Posted: Wed May 01, 2013 9:20 pm
Thanks mate. I also couldn't find anything especifically for Jimnys. It appears that nobody does that.
Vehicle: Jimny
Post Posted: Wed May 01, 2013 9:22 pm
Yes, they are. Just to emphasize...
PORL wrote:
Aren't all jimnys?
Post Posted: Wed May 01, 2013 9:25 pm
http://www.mountaingoatperformance.eu/s ... jimny.html
Google found these?
Vehicle: Jimny
Post Posted: Wed May 01, 2013 9:30 pm
Yes, but no photo and expensive.
I was thinking of some cheap PU or something you can inflate (just an idea)...
Post Posted: Thu May 02, 2013 9:55 am
2 pieces of rhs, 4 holes, 2 nuts, 2 bolts Thread is M10fine
Vehicle: SWB Sierra
Post Posted: Thu May 02, 2013 6:12 pm
Bits4vits sell alloy ones.
Post Posted: Thu May 02, 2013 6:17 pm
That's works for the rear but not for the front on a jimny. The bumps stops are pushed in and the only way to get them out are to get 2 screw drivers and lever them out. Chances are you will break them getting them out and will need new ones.
Only sort way I've thought of doing front bump stops on a jimny is to get a peace of 10mm plate, drill a hole and tap it out to 10mm then get a whole saw and cut the peace to suit the ID of the recess in side the front coil mount where the rubber bump stop sat. Weld the new peace into the recess and use jimny / vit bump stops with spacers to suit. I think this would be the best looking option.
Post Posted: Fri May 03, 2013 4:58 am
I made a cone in the front and welded it to the axle spring mount. Also stops the spring coming out of mine on full flex. It's not hard to cap a piece of pipe and weld it on.
Vehicle: Jimny
Post Posted: Fri May 03, 2013 9:58 am
It seems to be the way to go! Thanks a lot guys!
Users browsing this forum: No registered users and 197 guests
