| Author |
Message |
macguyverjimny
Joined: Mon Jan 03, 2011 9:06 pm Posts: 112 Location: SA
Vehicle: Jimny 2009 vvt JIL
 Posted: Sat May 04, 2013 11:39 pm |
Hi guy, How many guys with a 3 inch lift have experienced fall over? I am running 215 75 bf goodrich. Why is everyone with a jimny and a 3 inch lift have a rollcage? Does your jimny with a 3 inch feel top heavy,? Have you ever feel unsafe and felt like you are about to fall over? Thank you for all your help  I really need some of your guys opinions , i am referig to the jimnybits 75 mm lifts. Is it wise to do a 75 mm lift for a daily ride? Thank you.
Jezza86
Platinum Supporter
Joined: Tue Dec 06, 2011 9:30 am Posts: 2155 Location: Nhulunbuy 0880
Vehicle: 2010 jimny
 Posted: Sun May 05, 2013 12:46 am |
i have 55 mm, plus a 2" bodylift. untill recently i had a 70KG Hanibal impi hardcase camper on the roof of my jimny. with the camper on the roof it was pretty tippy and rocked around a lot on the road due to the soft as hell OME suspension, but you could feel it fairly well on the track and you knew your limits when driving on a incline. now the pods off and ive got 30x9.5s on and it feels awesome
joel
Joined: Wed Jan 27, 2010 10:30 pm Posts: 2191 Location: Dirranbandi
Vehicle: Sj70 tintop
 Posted: Sun May 05, 2013 7:13 am |
Skippy
Joined: Sat Apr 14, 2012 9:57 am Posts: 531 Location: Gold Coast
Vehicle: 2011 Jimny
 Posted: Sun May 05, 2013 8:54 am |
I have the Jimnybits 3'" lift, Bugsta is the only person i know of that has some sort of a rollcage.
I used to run my car with stock rims and 215's and not once felt i was going to tip over, now i run 30's and -13 rims and hammer around corners with no concern.
Ausuki
Vehicle: 93 Vitara -itty bitty lift
 Posted: Sun May 05, 2013 8:58 am |
Why would you run 215/75 tyres under a 3 inch lift?
Mike57
Joined: Fri Jul 22, 2011 11:09 am Posts: 1009 Location: Melbourne
Vehicle: Suzuki Jimny 2009
 Posted: Sun May 05, 2013 9:33 am |
Ausuki wrote: Why would you run 215/75 tyres under a 3 inch lift? x 2. A 40mm lift will be fine for this size.
31zook
Joined: Tue Mar 24, 2009 10:30 pm Posts: 9242 Location: maito
 Posted: Sun May 05, 2013 10:44 am |
215s will fit without any lift. And lifting your car 75mm won't be why it tips, it cause they use softer springs, and with the extra flex you get further up the track into the good section  Your worried over nothing
jimmy91
Vehicle: 2012 jimny
 Posted: Sun May 05, 2013 3:15 pm |
Ausuki wrote: Why would you run 215/75 tyres under a 3 inch lift? maybe because he fucking wants to
PORL
Joined: Fri Sep 17, 2010 8:42 am Posts: 262 Location: Beeliar WA
Vehicle: 2004 Jimny 1.6
 Posted: Sun May 05, 2013 3:28 pm |
Skippy, any scrub with your set up? Have you chopped your guards?
monley
Joined: Wed Nov 24, 2010 7:58 am Posts: 11092 Location: Mandurah.W.A.
 Posted: Sun May 05, 2013 3:35 pm |
jimmy91 wrote: Ausuki wrote: Why would you run 215/75 tyres under a 3 inch lift? maybe because he fucking wants to Its a silly idea When i build my next jimny it will have 2" body lift and 31's. No spring lift this time around Low Is the go
_________________ Tell my arse, he actually gives a crap!
PORL
 Posted: Sun May 05, 2013 3:39 pm |
monley wrote: jimmy91 wrote: Ausuki wrote: Why would you run 215/75 tyres under a 3 inch lift? maybe because he fucking wants to Its silly idea When i build my next jimny it will have 2" body lift and 31's. No spring lift this time around Low Is the go  This Is interesting
atari4x4
 Posted: Sun May 05, 2013 3:43 pm |
slant angle?  jimmy91 wrote: Ausuki wrote: Why would you run 215/75 tyres under a 3 inch lift? maybe because he fucking wants to  brake the string on the tampon this morning?
kristov
Joined: Wed Oct 12, 2011 8:47 pm Posts: 347 Location: Bunbury, WA
Vehicle: 2011 jimny
monley wrote: jimmy91 wrote: Ausuki wrote: Why would you run 215/75 tyres under a 3 inch lift? maybe because he fucking wants to Its a silly idea When i build my next jimny it will have 2" body lift and 31's. No spring lift this time around Low Is the go  agreed kinda wish i never got my 2 inch lift i liked it stock height much stable cog
zooky08
Joined: Fri Nov 27, 2009 10:30 pm Posts: 3426 Location: imbil/gympie. qld
 Posted: Sun May 05, 2013 4:00 pm |
I ran a 75mm lift with 215 as well. Wasnt tippy at all. Then i ran 30's with wide rims. Was stable as. I have rarely picked up a wheel. Atm im setting my jimny up with no lift at all with 30's. See how I go.
_________________ 03 Jimny 30 km2s 75mm lift f&r locked winch
jimmy91
Vehicle: 2012 jimny
 Posted: Sun May 05, 2013 4:47 pm |
atari4x4 wrote: slant angle?  jimmy91 wrote: Ausuki wrote: Why would you run 215/75 tyres under a 3 inch lift? maybe because he fucking wants to  brake the string on the tampon this morning?  that was yesterday :p just beacuse he has 3 inch doesnt mean he has to run 29's or 30's its his car let him do it how he wants.
macguyverjimny
 Posted: Sun May 05, 2013 4:58 pm |
hey guys. i just am very scared to make it unsafe, I am not soon goint to put 29's or 30's on my jimny, my tired is really still in a very good condition, i have the 215 75 on with the stock suspention but want more articulation, just very scared thaf 3 inch might be too high and dangerous. thank you for everyones opinion
jimmy91
Vehicle: 2012 jimny
 Posted: Sun May 05, 2013 5:02 pm |
then go 2inch and put a rear locker in. i had 215/75 and a 2 inch ironman kit it was pretty good.
shep
Joined: Thu Mar 29, 2007 11:30 pm Posts: 14498 Location: Here there everywhere
 Posted: Sun May 05, 2013 5:28 pm |
I am going to lift mine about 6" with a combo of tyres and springs but seeing as it will be a lot wider the cog should be close to stock
_________________ JEEPJEEPJEEPJEEPJEEPJEEPJEEPJEEPJEEP
Jezza86
Platinum Supporter
Vehicle: 2010 jimny
 Posted: Sun May 05, 2013 6:39 pm |
you'd have to be doing something either really serious, or seriously wrong to wind up needing a roll cage. on standard rims i guess your not going to be rock crawling over boulders up a washed out creek? not saying dont give it a go but where is it where your planing to go thats making you so paranoid? i was paranoid about tiping when i first took my jimny offroad just in the bush, as i was inexperienced and to a certain extent still am.
what i did to ease the nerves was go put it on a odd angle, pull on the handbrake, and get out and rock it. shake the car and feel the suspension and youl understand how stable it is from stock. then i put it on a bigger angle. i never tipped it but i did this a fair bit, in between geting in the car and seing how the angle felt from inside.
my mistake when first buying my jimny was rushing in and buying things before learning to drive itlike a jimny you can spend a lot of money early or you can upgrade once you find your limits. it just depends where you want to go, and if you have too much cash in your pocket.
a lot of cars here are projects, hobbys or toys. you maynot need to go to the extremes of what you see on auszookers. however in saying that its a great see the creame of the crop for inspiration once you get into it. and you will when you understand what that car can actually do, stock
joel
 Posted: Sun May 05, 2013 7:10 pm |
i went 2'' with very heavy duty coils, as im only planning for 215's and carrying a fair bit of weight (thus the HD springs) its a bit of a pain around town, but in the next few weeks i will have an update in my build thread which will explain why i went the HD springs.
macguyverjimny
 Posted: Sun May 05, 2013 7:17 pm |
Thank you. I am more and more thinking about doing it and then lower the suspention as i go along if i dont like it. I have had my car since 2009, and did thing to it as i got the money.,its fabulous offroad and really love it and find it useless tospend money on it if i wont be ussing the mods, I finf my groundclearance a constant issue on every 4x4 trail i do. That is why i want the 3 inch, to gain articulation and to prevent my car bashing on its belly over rocky sections, but i dont want to be scared when doing some hill where my car will articulates, and feel like im about to fall over, i have some experience doing stuff and really have been driving my jimny offroad for some time, i have never felt unsafe on stock suspention ,i dint believe in doing risky things like attaching a hill or a downhill at angle that is not 90 degrees. Hope this explain my needs  thanx
sideways
Joined: Fri Oct 29, 2010 1:53 pm Posts: 5944 Location: Northcliffe, W.A.
 Posted: Sun May 05, 2013 7:29 pm |
macguyverjimny wrote: hey guys. i just am very scared to make it unsafe, I am not soon goint to put 29's or 30's on my jimny, my tired is really still in a very good condition, i have the 215 75 on with the stock suspention but want more articulation, just very scared thaf 3 inch might be too high and dangerous. thank you for everyones opinion  It really doesn't make that much difference. If you manage to put it on its side with a 3" lift, you probably will with no lift. You get a lot of warning signs before it'l go over.
Scales
Joined: Mon May 30, 2011 9:28 am Posts: 2233 Location: Townsville
 Posted: Sun May 05, 2013 7:52 pm |
i got 3" and 215's... nothing wrong with that config... why so much hate? Mine feels safe as houses and doesnt look retarded in any way with "small tyres" I think it suits it quite well and is nice and capable.
If you dont have a locker youll be spinning wheels before you have any worry of going over (most of the time) Look at my build thread if you want to see what it looks like a bit more
macguyverjimny
 Posted: Sun May 05, 2013 8:15 pm |
Why so much hate? Went the weekend to a guy who is reallly good with vehicle dynamics and have been into alot of extrem 4x4 challenges to discuss the manufacturing of custom radius arms for a 3 inch lift. So after what he said i decided to get myselfrather the caster correction bushes, But he said 3 inch is way too much, and he will do 2 inch on most . He also said that even on a land cruiser station wagon is 3 inch too much. So that is why i am so scared, he said if i want to take my offroad seriously then i should rather do 2 inch because when driving side dlopes on inclines on downhills it will be dangerous. So i am really just scared about tipping, So that is more or less what i am worried about, i purchased the 3 inch jimny coils from jimnybits , and its the diesel version,so it is apperently a little longer even than the pertol ones but i do have a bar and winch so hopefully it will bring it a little bit down. Hope this explain my concerns. Thank you.
PORL
 Posted: Sun May 05, 2013 8:40 pm |
You need to chill lol. You will be fine. Don't listen to that guy. If you are going to roll then your doing somthing you will know is a bad idea. Fit the lift and drive to your ability, learn how your Jim handles different situations, you will be fine. I have a 2inch lift ATM and am buying the 3 inch shortly. Just remember if it feels scetchy then it probs is. Enjoy you'll be fine
macguyverjimny
 Posted: Sun May 05, 2013 9:54 pm |
Thank you  Saw this vid and i got the shakes, Seems his front wheels slipped on the slopes and the front wheels was turned a bit sideways, while reversing. See link http://www.youtube.com/watch?v=r0SjQKF_34AThanx  will probily go through with the 3 inch This vid also scares me, seems unstable but wont be comfortable riding there, too risky. http://www.youtube.com/watch?v=Tirv6O8RG7EThank you guys  love the auszookers community  very hardcore
Last edited by macguyverjimny on Sun May 05, 2013 10:02 pm, edited 1 time in total.
jimmy91
Vehicle: 2012 jimny
 Posted: Sun May 05, 2013 9:58 pm |
More lift the better to a point. 3 inch isn't big at all for a cruiser it's pretty basic.
stockman
Joined: Thu Nov 05, 2009 10:30 pm Posts: 5319 Location: Canberra
Vehicle: 4wd
 Posted: Sun May 05, 2013 10:15 pm |
jimmy91 wrote: More lift the better to a point. 3 inch isn't big at all for a cruiser it's pretty basic. I'd love to hear your logic.
_________________ Watch out or you'll get sued.
Matthew
Joined: Mon Jun 15, 2009 11:30 pm Posts: 472 Location: S.E. Melbourne
Vehicle: SWB Sierra
 Posted: Sun May 05, 2013 10:32 pm |
macguyverjimny wrote: Thank you  Saw this vid and i got the shakes, Seems his front wheels slipped on the slopes and the front wheels was turned a bit sideways, while reversing. The problem was he wasn't in reverse. The car was sliding backwards, looks like he had a bit of right hand down, but due to locked wheels the slope took control.
want33s
Joined: Fri Nov 16, 2007 10:30 pm Posts: 8134 Location: Sunshine Coast Qld
 Posted: Sun May 05, 2013 11:59 pm |
macguyverjimny wrote: Saw this vid and i got the shakes, Seems his front wheels slipped on the slopes and the front wheels was turned a bit sideways, while reversing. http://www.youtube.com/watch?v=r0SjQKF_34AThis vid also scares me, seems unstable but wont be comfortable riding there, too risky. http://www.youtube.com/watch?v=Tirv6O8RG7EBoth of those videos have the same theme and it's got nothing to do with any lift......... Its DRIVER ERROR.
