| Author |
Message |
shep
Joined: Thu Mar 29, 2007 11:30 pm Posts: 14498 Location: Here there everywhere
 Posted: Mon Jul 20, 2009 12:28 pm |
what do i need to do to move the rear shock top mount towards the middle of the car. photos would be good.
lump_a_charcoal
Joined: Wed Feb 28, 2007 10:30 pm Posts: 4454 Location: Botany, NSW
Vehicle: MY2019 Jimny
 Posted: Mon Jul 20, 2009 2:04 pm |
First things first, you will need a few milk crates...
BlueSuzy
 Posted: Mon Jul 20, 2009 2:47 pm |
royce
 Posted: Mon Jul 20, 2009 4:11 pm |
bit of flat, drill holes to bolt it to standard mounts
then drill holes in middle of flat where you want shocks to be
whats taking so long
lump_a_charcoal
 Posted: Mon Jul 20, 2009 4:17 pm |
Sky Upper Rear Shock Mount, on the same page Timmy posted.
shep
 Posted: Mon Jul 20, 2009 4:27 pm |
shep wrote: what do i need to do to move the rear shock top mount towards the middle of the car, using stuff that is laying around or close to free. photos would be good.
what i should have posted.
royce, would 40x3 bar do the trick.
BlueSuzy
 Posted: Mon Jul 20, 2009 4:33 pm |
i wasnt saying BUY THAT! Looks piece of piss to make. flatbar/tube mock up with crates, easy as.
royce
 Posted: Mon Jul 20, 2009 5:18 pm |
think I used 50 x 4, 40x 3 might work
steve
Joined: Sun Jun 11, 2006 11:30 pm Posts: 7681 Location: Brisbane
Vehicle: 75 Cruiser
 Posted: Mon Jul 20, 2009 6:07 pm |
i need to do this too so i can remove my bumpstops... but gees 3mm would be thin eh? I'd want to use 5mm i think.
ball
Joined: Wed Oct 22, 2008 10:30 pm Posts: 4673 Location: Katherine
 Posted: Mon Jul 20, 2009 6:16 pm |
If 4 or 5 mm is adequate for most people, my calculations would put the required thickness @ 10-12mm to make the whole thing shep proof
shep
 Posted: Mon Jul 20, 2009 6:24 pm |
piss off ball.
um have you got any 10mm bar laying around
ball
 Posted: Mon Jul 20, 2009 6:28 pm |
shep wrote: piss off ball. um have you got any 10mm bar laying around
No but I have some 90x90x12 angle you can trim up
Damo
Joined: Sat Jul 22, 2006 11:30 pm Posts: 4661 Location: Brisbane
 Posted: Mon Jul 20, 2009 11:59 pm |
I think that if you used flat bar (unless you went to 12mm as ball suggested) it's going to flex a lot. I'd be inclined to used RHS. In fact I have some 3mm wall 50x25 that i'm going to make mine out of. Eventually.
_________________ SJ50.4.LYF
Built4thrashing
Joined: Wed May 21, 2008 11:30 pm Posts: 4972 Location: Dandenong .Vic
 Posted: Tue Jul 21, 2009 12:11 am |
I made my own years ago before you could buy one on the net. I used 40mm rhs mounted to original mounts with new holes drilled where i wanted the shocks. Im using Triton rear hydrolic shocks. Nice and soft and long enough to out travel the suspension.
_________________ B4T
Damo
 Posted: Thu Jul 23, 2009 12:21 am |
This is what i've been working on. In my usual style I have made things as difficult as possible, but hey it bolts straight on. Except for the part where you have to move my fuel filter and re-route the exhaust  i'm such a spastic...
It's held to the chassis with 4 u-bolts that have been cut down to j-bolts. The shock is rear Commodore sedan. They are longer than the wagon shocks, probably too long. I will be spacing my bumpstops down to stop them bottoming out.
shep
 Posted: Thu Jul 23, 2009 12:24 am |
thanks damo looks good. i wont have the same problems with the exhaust as mine is a 3mtr piece of 2" flex
Damo
 Posted: Thu Jul 23, 2009 12:28 am |
shep wrote: thanks damo looks good. i wont have the same problems with the exhaust as mine is a 3mtr piece of 2" flex
shep
 Posted: Thu Jul 23, 2009 12:45 am |
they had a minimum buy length of 3 mtr so i just used the lot.
boyd84
Joined: Wed Jun 30, 2010 1:21 am Posts: 45 Location: brisbane
Vehicle: boyd offroad
 Posted: Mon Jul 11, 2011 5:05 am |
How far should you have your shocks apart? herd that if you have them to close its not good on your shocks and they wont work aswell.
DropBear8
Joined: Tue Oct 19, 2010 12:00 pm Posts: 556 Location: Perth
 Posted: Mon Jul 11, 2011 5:30 am |
Boyd i think youd be more refferring to the angle of the shock.
If the angle on the shock is to steep it puts a large amount of stress in the shock. Making its ability to do its job harder. As it now requires more force to get the shock to engage. This would make you car feel like an overall harder suspension and cause you to feel more bumps on the road.
But im no expert so im probably wrong
_________________ screwdriver's on ur head impale DropBears
Ben_Sierra
Joined: Wed Sep 30, 2009 11:30 pm Posts: 4472 Location: Perth
 Posted: Mon Jul 11, 2011 5:32 am |
DropBear8 wrote: Boyd i think youd be more refferring to the angle of the shock. If the angle on the shock is to steep it puts a large amount of stress in the shock. Making its ability to do its job harder. As it now requires more force to get the shock to engage. This would make you car feel like an overall harder suspension and cause you to feel more bumps on the road. But im no expert so im probably wrong
The more angle the less the damping effect, so you need a heavier shock to get the same damping, otherwise its too soft...
_________________ I want my old sig back
DropBear8
 Posted: Mon Jul 11, 2011 5:39 am |
Ben_Sierra wrote: DropBear8 wrote: Boyd i think youd be more refferring to the angle of the shock. If the angle on the shock is to steep it puts a large amount of stress in the shock. Making its ability to do its job harder. As it now requires more force to get the shock to engage. This would make you car feel like an overall harder suspension and cause you to feel more bumps on the road. But im no expert so im probably wrong  The more angle the less the damping effect, so you need a heavier shock to get the same damping, otherwise its too soft...
Ahhh yea, im thinking about it right now.
On a greater angle the same force will be greater in the shock causing it to compress more then on a lesser angle. So a stiffer shock will be able withstand this greater force.
Thanks for clearing that up.
Ben_Sierra
 Posted: Mon Jul 11, 2011 6:02 am |
Still not convinced you've got it... Stand by for noobCAD explanation...
Ben_Sierra
 Posted: Mon Jul 11, 2011 6:15 am |
So, D is the damping force of the shock. v is the vertical component of it, that is, the component of the force which opposes vertical movement of the axle. a is the angle of the shock...
So, at a=90 (shock vertical) you get all of D acting vertically.
At a = 60, you get 86% of D
At a = 45, 70%
At a = 30, 50%
At a = 0, you get no damping in the vertical direction...
DropBear8
 Posted: Mon Jul 11, 2011 6:25 am |
Ahhhh yea i understoodz where i was wrong now.
The whole thing
Thanks for clearing it up Ben. I was somehow thinking sine of a angle equals a number greater than one.
Ben_Sierra
 Posted: Mon Jul 11, 2011 6:32 am |
Its also worth noting that the Damping force D is also proportional to the speed that the shock is being compressed at, i.e. the compnent of the speed in the direction of the shock, which decreases in the same proportion as v, so the more angle on the shocks, the less the rate of compression and the less damping force the shock provides in the first place... So its a double whammy...
DropBear8
 Posted: Mon Jul 11, 2011 6:38 am |
So what is benefit from doing this.
JrZook
 Posted: Mon Jul 11, 2011 6:47 am |
DropBear8 wrote: So what is benefit from doing this.
More wheel travel to shock travel. The travel of the shock generally limits the total wheel travel if you have your suspension sorted.
_________________ Lil Foot!
