It is currently Wed Nov 04, 2026 4:29 pm
Vehicle: 1985 LWB sierra
Post Posted: Wed May 29, 2013 4:58 pm
Hey guys as the title says all I need to get my Sierra running is finding out which plug goes we're and what connections I need to change, so if you have done this conversion could you please put pics up or advise me were they go, mainly the ones that are on the Carby.
Jeremy!!
Post Posted: Wed May 29, 2013 5:24 pm
Are you running the G16a Carby?
Post Posted: Wed May 29, 2013 6:01 pm
Yeah that's the term for Carby and G16b is fuel injected.
Post Posted: Wed May 29, 2013 9:00 pm
Yeah i realise that.. however they're are different carbys available to suit, for instant i'm running my g16a with the sierra g13ba carby. So i'll go with the assumption that you are running the g16a carby?
Post Posted: Wed May 29, 2013 9:20 pm
Hey mate, all wires will most likely go to same locations they did on the original engine. The fittings are different on a few of them. Simply cut them off and join the fitting on that came off the loom of the g16a. I think it is alternator, and a few sensor wires. The only pain in the ass is the plug that comes off the carby. It has 4 wires, and your sierra loom only has 3. 2 of the wires can be bridged together to form 3 wires in total off the carb. Can't remember which exactly, I may be able to find some photos if you need them. Also keep in mind there is the temp sensor off the thermostat, which uses the same style plug as the starter motor, so if she won't start, then they are round the wrong way. Hope this helps.
Post Posted: Wed May 29, 2013 9:24 pm
Yeah vitar Carby. I would love some pixies please!
Post Posted: Thu May 30, 2013 5:15 pm
I'll try get some to ya tomorrow been finishing wel late hahaha
I'll try get some to ya tomorrow been finishing work late hahaha
Post Posted: Thu May 30, 2013 6:00 pm
Thanks mate, all I need to know is which of the two out of the four wires I need to connect and I have a single little white plug which I can't find a home for.
Post Posted: Thu May 30, 2013 8:51 pm
Hey mate I have been trying to find the photos dave sent me originally but can't seem to. He helped me sort it and it worked a treat. Wires on my car all taped up unfortunately.
Post Posted: Thu May 30, 2013 8:59 pm
That's okay, do you have I little one wire connection that you couldn't find a home for?
Post Posted: Thu May 30, 2013 9:02 pm
Did a little searching on my photobucket and found a half decent pic hahaha... If you can solder and heat shrink for a good connection....
Post Posted: Fri May 31, 2013 6:46 am
Yeah I'm Pruitt handy with the soldering iron, thanks very much Dave!
Post Posted: Fri May 31, 2013 8:34 am
No problem buddy anytime hopefully it all goes well for ya...
Post Posted: Fri May 31, 2013 10:35 am
Me to! Just need to get the exhaust re bent, won't be going for another 3-4 tho, my dad is going up north for the V8s and I still have 46 days till I can get my learners :(
Post Posted: Sat Jun 08, 2013 8:39 am
Daves4wd wrote:
Did you cut the plug off the carb or the loom end?? Send me a pic of what you got and ill see what ya got bud ill get a couple freash pics tomorrow if I get time going camping to test out a new setup I've got going hahaha.... Plus I need a exscuse to neaten up the wires hahah
I'm cutting the loom end and replacing it with the vitara plug ( wires were to short for my like to solder ) so im going to join what ever wire go together on the vitara carby plug and hard wire them into the sierra loom. here is a few pics, some of them came out looking like the carby is on the wrong side sorry.
sierra loom ( only 2 wires )
Users browsing this forum: Google [Bot] and 256 guests
