It is currently Wed Nov 04, 2026 7:08 pm
Post Posted: Tue Jun 04, 2013 6:01 am
I want bigger front brakes on my 2013 abs jimny, what fits while keeping the abs working properly? I do have a set of lwb vit callipers but no rotors.
Post Posted: Tue Jun 04, 2013 6:15 am
Does it have vented rotors currently?
Post Posted: Tue Jun 04, 2013 6:23 am
Dunno.
Post Posted: Tue Jun 04, 2013 2:45 pm
Don't do anything until you get the full floaters with discs. You won't need an upgrade.
Post Posted: Tue Jun 04, 2013 6:46 pm
I have everything I need for this except the kit from BenT.
Vehicle: Sj70 tintop
Post Posted: Tue Jun 04, 2013 7:30 pm
standard rotors arent vented.
Post Posted: Tue Jun 04, 2013 7:31 pm
tell me more joe.
is this abs compatible?
and when will they be in production and $$??
what else do you make for jimnys?
cheers
joel
Post Posted: Tue Jun 04, 2013 8:07 pm
PM sent.
Post Posted: Fri Jun 07, 2013 6:59 am
Someone must be able to point me towards a front brake upgrade? I don't like the idea of just upgrading the rear brakes especially when I plan to tow pretty close to the max weight limit on dirt roads.
Vehicle: Suzuki Jimny 2010
Post Posted: Fri Jun 07, 2013 7:28 am
Lwb vitara rotors and calipers. You may need to get the centre of the rotor machined out approx 1.3?mm. Pm 31zook and he will confirm which ones he is using. He will have the ones that fit directly onto the 99-05 model, 06+are slightly bigger centre hole :)
Post Posted: Fri Jun 07, 2013 7:42 am
Shep, Towing heavy loads, I'd be wanting to do the rear brakes to. Perhaps a good place to start.
Post Posted: Fri Jun 07, 2013 9:47 am
:wink:
Vehicle: 2012 Jimny
Post Posted: Sat Jun 08, 2013 6:19 pm
I'm keen on a front upgrade as well has any one actually swapped over to vit lwb calipers/rotors on a jim yet on auszookers? is the caliper a straight bolt on?
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 205 guests
