It is currently Fri Oct 30, 2026 2:13 pm
Vehicle: 95 sj70 and 78 lj81
Post Posted: Mon Jun 10, 2013 5:17 pm
I was wondering today how much higher(or lower) my 81 is from standard
Has anyone got any measurements of a standard model say from ground to bottom of chassis rail at the front and back and from ground to the door sill?
Post Posted: Mon Jun 10, 2013 8:22 pm
X2.. also what's the Length of a LJ81.. :P
Vehicle: LJ80 Stockman
Post Posted: Mon Jun 10, 2013 9:01 pm
Ive got a scanned owner's manual, and it states the dimensions.
Post Posted: Mon Jun 10, 2013 10:53 pm
Here's some measurements I got off my LJ80v. Mega sagged original springs and Sierra size tyres.
Because I'm a numbers man I measured up a whole bunch of things today.
Just to clarify, stock car, original everything but the wheels and tyres which are sierra size. approx 50kgs load in the back and a full tank of fuel.
Front diff clearance. 205mm
Rear diff clearance. 210mm
Front spring pad (measured from the end without the shock mount) clearance. 240mm
Rear pad. 220mm
Front shock clearance. 215mm
Rear shock 200mm
Passengers Sill clearance. 330mm
Drivers sill 320mm
Front bumper clearance 380mm
Rear bumper 475mm
Exhaust muffler clearance. 170mm
Front drivers spring hanger clearance (measured ti the bottom of the main leaf directly under the spring hanger bolt) 225mm
Front drivers shackle clearance 295mm
Front passengers spring hanger 230mm
Front passengers shackle 295mm
Rear drivers spring hanger 265mm
Rear drivers shackle 345mm
Rear passengers spring hanger 270mm
Rear passengers shackle 350mm
I flexed it up a while ago by driving down* a ground level loading ramp with the passengers wheel staying at ground level. I drove until it started to lift a wheel. There was no load and I didn't jiggle it around to get more flex out of it or anything.
LJ80s have the same front shocks as Sierras and the back is the same setup as the front with a pin top, eye bottom shock mounted outside the chassis rails with slightly longer shocks. All stock suspension, even the bushes are probably original (no mention of them being changed in the 21 year service history). Measurements are from the centre of the shock eye to the top on the mount on the chassis (ie, where the top rubber contacts the mount)
Front passengers compressed 320mm (on bumpstop)
Front drivers extended 405mm
Rear passengers extended. 450mm
Rear drivers compressed 345mm (on bumpstop)
*Forwards, as in nose first. With my other LJ I got significantly better flex if I reversed down it but you don't reverse everywhere so this is more real world. I might try reversing this one later and see if I can force any more flex out of it.
viewtopic.php?f=4&t=37003&p=743584&hilit=stockman#p743584
Post Posted: Tue Jun 11, 2013 6:21 pm
Thanks sideways definitely some numbers there. Unfortunate not the ones I'm after
I really need a standard LJ on LJ tires or equiv diam And the measurements from the ground to the bottom of the chassis front and back and ground to the top of the door sill. Any help would be appreciated
Post Posted: Tue Jun 11, 2013 6:54 pm
From my stuff you could easily figure out the clearance with standard size tyres. When I measured all that up the front tyres measured 26" and the rears 25". IIRC I calculated it and there was around an inch of sag in the front suspension, never measured the rear but it seemed less.
So add 2" front and back and that's about as accurate as you'l get.
Mine's on bartreads now but it has lifted springs. It's also 300kms away. :P
Post Posted: Tue Jun 11, 2013 8:41 pm
I measured up my standard lj81 which is on 6,16 bartreads with standard suspension
Front 445mm
Rear 520mm
Door sill 1120mm
Overall length 3600mm
Post Posted: Tue Jun 11, 2013 8:50 pm
Front 445mm
Rear 520mm
Door sill 1120mm
2 foot body lift? :lol:
Post Posted: Tue Jun 11, 2013 8:54 pm
I should've said window sill :oops: and just to make you feel better sideways I will be driving mine to work again tomorrow :thefinger:
Post Posted: Tue Jun 11, 2013 10:02 pm
Makes sense. :lol:
Mum is driving mine to work tomorrow. :cry: Found any F10as in your travels? :P
Post Posted: Tue Jun 11, 2013 10:20 pm
I found one but it turned out to have a large hole in the side of it but I'll keep looking
Post Posted: Wed Jun 12, 2013 6:50 am
Thanks Troopy
Users browsing this forum: Google [Bot] and 411 guests
