It is currently Sun Nov 15, 2026 4:27 am
Post new topic Reply to topic  [ 35 posts ]  Go to page Previous  1, 2
Post Posted: Wed Jun 12, 2013 1:07 pm
triple check both the crown wheel & pinion, there is a tooth count listed in this thread but of course it doesn't have 4.8:1 listed.
viewtopic.php?f=17&t=6614&hilit=diff+ratio
Post Posted: Wed Jun 12, 2013 4:20 pm
I am a fool! I pulled everything appart cleaned off all the Aluminum metal filings and there are 39 teeth on the crown and 8 oth the pinion part, they are very damaged so I guess thats how three people miss counted. Thanks for the help.
Post Posted: Wed Jun 12, 2013 4:51 pm
4.8's & i sold the set out of the blagon but at least you're on the right track.
Post Posted: Wed Jun 12, 2013 5:53 pm
christover1 wrote:
Is it possible a previous owner did a ratio change?
chris, i've said it before... not too many people bother doing the swap & why would you want to go from a 4.8 to a 4.3, would make it sluggish as hell???
plus, i'm certain it was a pristine one owner unmodified example before he picked it up.
this would also put the speedo WAY out on standard tyres & massively out on big tyres making it easy to pick if it was the case. :wink:
Post Posted: Wed Jun 12, 2013 7:02 pm
ole
Yeah its all good, I pulled the diff out and its clear that I need an entire new one. Everything is ruined from the crown wheel, housing on both sides, pinion, all gears are munched. I have found a whole diff with 4.8's for $360 shipped over which seems like a very easy fix.
Although Ive been with out a car for so long im not sue what I will do with it ha ha ha
