| Author |
Message |
magnat
Joined: Sat Jul 28, 2007 11:30 pm Posts: 1066 Location: Southern Highlands N
 Posted: Wed Jun 12, 2013 10:15 am |
I am looking into getting the XL-7 lifted. Most kits I have seen have been between 25mm and 40mm. I am considering a Dobinson 40mm lift kit as Tough Dog is too much money..
What exactly are the benefits to a 40mm lift ?
tanshi
 Posted: Wed Jun 12, 2013 10:17 am |
that is a strange question. your wanting to lift the car but you want to know the benefits??
i think you need to be more specific
magnat
 Posted: Wed Jun 12, 2013 10:25 am |
Well... On the weekend on a mild track I bottomed out a little.. So If a 40mm Lift will assist I am all for it.. Bash plates helped me glide over the mud instead of shovelling into it.. I also hope to eliminate the XL-7's loose feeling rear end..
tanshi
 Posted: Wed Jun 12, 2013 10:29 am |
40mm is going to help a little obviously. its going to help clear things 40mm higher.
Joined: Sat Aug 12, 2006 11:30 pm Posts: 6456 Location: Radelaide ofcourse!
 Posted: Wed Jun 12, 2013 11:27 am |
The lift will help a little in the front half of the car, but rear diff pumpkin will still be there in the same place unless bigger tyres are fitted. As has been mentioned before if your still running the original springs, it will lift it slightly more as the originals wouldve sagged somewhat and the on road handling is generally better with a firmer aftermarket spring. When I bought mine and drove it home through the hills it was wallowing all over the shop. New springs, struts and shocks stopped that. Although I've recently gained a little body roll with the removal of the sway bar.
_________________ Chop
atari4x4
 Posted: Wed Jun 12, 2013 11:30 am |
i think the extra weight & length also doesn't help, my LWB with the exact same set up handles like a bag of dicks in the twisty stuff compared to my SWB.
magnat
 Posted: Wed Jun 12, 2013 12:25 pm |
So disconnecting the rear sway bar allows for more Droop ?
atari4x4
 Posted: Wed Jun 12, 2013 12:53 pm |
there is no rear sway bar, chop is talking about the front.
GeckoXL7
Joined: Tue Sep 25, 2012 8:12 pm Posts: 1173 Location: VIC
Vehicle: 2002 Suzuki XL7
 Posted: Wed Jun 12, 2013 1:17 pm |
Main thing with the XL-7 is ramp over clearance, need a balance between tire size and suspension lift. Check your rear trailing arm and panrod bushes if your rear end is handling weird. Stiffer springs like dobs or kings does help a bit. So do you still have the standard springs in? Im putting mines through a engineer and need the standard height from ground to center lip of wheel arch on front and rear. got it from your thread but according to the difference i have 6.5" lift in rear which just cant be correct  Depending on mods it shouldn't cost me a arm and a leg either.
atari4x4
 Posted: Wed Jun 12, 2013 1:21 pm |
 Posted: Wed Jun 12, 2013 2:57 pm |
GeckoXL7 wrote: Main thing with the XL-7 is ramp over clearance, need a balance between tire size and suspension lift. Check your rear trailing arm and panrod bushes if your rear end is handling weird. Stiffer springs like dobs or kings does help a bit. So do you still have the standard springs in? Im putting mines through a engineer and need the standard height from ground to center lip of wheel arch on front and rear. got it from your thread but according to the difference i have 6.5" lift in rear which just cant be correct  Depending on mods it shouldn't cost me a arm and a leg either. You been done for mods? Why would you put it through an engineer unless you had to? I've passed yours on port road not long ago and unless you've huge mods since then yours looks stock as a rock. If it looked like Klutched's gv then I would worry about it.
GeckoXL7
 Posted: Wed Jun 12, 2013 3:30 pm |
Nah havent been, but just looked into it at moment front is pretty much stock cause of winch its only 12mm higher, rear is 47mm.
Im just looking at it as peace of mind esp insurance wise and just something to shove in peoples face if they question it, which some have. if it was over a grand i wouldn't bother, but since its less im looking at the options.
I can either stick with 2" lift and a extra inch in tire height, or go down to 1 inch lift and 1 inch tire height and just get a placard made up which is a much easier and cheaper option just as long as the tires don't rub.
magnat
 Posted: Thu Jun 13, 2013 12:58 pm |
So I am guessing 40mm should be enough for me to fit larger diametre tyres to raise the diff ?
GeckoXL7
 Posted: Thu Jun 13, 2013 1:06 pm |
Yep at that height I had no issues with 235 70 r16. But 225 75 r16 seems to be pretty good.
alexxx
Joined: Sun Aug 05, 2012 9:49 pm Posts: 823 Location: Adelaide
Vehicle: Ford Maverick 4.2 Diesel
 Posted: Mon Jun 17, 2013 10:10 pm |
GeckoXL7 wrote: Nah havent been, but just looked into it at moment front is pretty much stock cause of winch its only 12mm higher, rear is 47mm.
I can either stick with 2" lift and a extra inch in tire height, or go down to 1 inch lift and 1 inch tire height and just get a placard made up which is a much easier and cheaper option just as long as the tires don't rub. spend the money on bigger tyres bud. waste of money getting it engineered. you will never get hassled over it
alexxx
 Posted: Mon Jun 17, 2013 10:12 pm |
i have a fair sized lift plus bigger tyres and told the insurance company and they covered it no worries
vitzookman
Joined: Wed Feb 16, 2011 6:14 am Posts: 347 Location: Bris
Vehicle: 2001 XL7
 Posted: Tue Jun 18, 2013 10:48 am |
I told the insurance company the XL7 is lifted and they said i can have any size tyre i want as long as i have the factory rims on it, so i signed up  i have been out at the glass house mountains a few times with friends that had XL7s too and the amount of scrapping that was done over mounds was annoying, now with the lift and tyres on mine it has been fine but if i pushed im sure i could get it to scrap again lol.
magnat
 Posted: Tue Jun 18, 2013 11:28 am |
Well I have booked it in to get a 40mm lift.. should help against bottoming out. I mean I love the space but you cannot have an offroad machine with a long wheel base without the inevitable poor ramp over.. So it should help a little..
vitzookman
Vehicle: 2001 XL7
 Posted: Tue Jun 18, 2013 11:40 am |
Yay!
banga
Joined: Tue Nov 17, 2009 10:30 pm Posts: 668 Location: sunshine coast
 Posted: Tue Jun 18, 2013 12:09 pm |
atari4x4 wrote: i think the extra weight & length also doesn't help, my LWB with the exact same set up handles like a bag of dicks in the twisty stuff compared to my SWB. is that with the calmini springs in it? mine handles pretty shit. have you driven the lwb calmini'd and with stock rims. only about 9999999999999999999999999billion times better with neg 13's
atari4x4
 Posted: Tue Jun 18, 2013 12:14 pm |
banga wrote: atari4x4 wrote: i think the extra weight & length also doesn't help, my LWB with the exact same set up handles like a bag of dicks in the twisty stuff compared to my SWB. is that with the calmini springs in it? mine handles pretty shit. have you driven the lwb calmini'd and with stock rims. only about 9999999999999999999999999billion times better with neg 13's yeah exactly the same calmini set up as what was in the silver swb & nah i haven't driven either one lifted on stockies... i imagine it would be terrible though.
Farkyard
Joined: Mon Dec 10, 2012 1:38 pm Posts: 111 Location: Don, Tasmania
Vehicle: 2002 XL7
 Posted: Sun Jun 23, 2013 8:59 am |
Mine handled better instantly with the lift. Just make sure you get a wheel alignment done and then checked again maybe about 500klms or so afterwards. I wish I had of as wouldn't be looking at two just about destroyed front tyres. Appears either wasn't done after fit up or extra weight of bullbar and winch combined with natural settling of springs completely screwed with with it.
magnat
 Posted: Sun Jun 23, 2013 9:57 am |
Thanks Farkyard.. It will all get done next tuesday... Lift, Camber bolts and wheel alignment..
