It is currently Sun Nov 01, 2026 1:18 pm
Vehicle: 92 softop w/GTi motor
Post Posted: Wed Jun 12, 2013 3:18 pm
Hey guys,
Went for a wheel on the weekend and this wiring fault crops up,First time its happened and ive checked the usual suspects (earths and fusing)Im not a complete electrical novice but this has me stumped....Ive googled the problem and found another bloke with a sierra with the same problem but he didnt mention the fix.im hopeing it may be one of those sierra things that someone knows about.I did crush the drivers side sill but fairly sure no wiring runs in it.
Car is 92 WT SWB soft top
The problem:
1. No stop/tail lights at all
2. High beam indicator light comes on when you hit the brakes
3. Stereo has stopped working (has its own earth direct to chassis and both wires still show 12v when tested)
4. Clock has a mind of its own
5. No dash lights
No wiring burning/sparks or anything suss like that just happened all at once.im sure its just an earth but any ideas on where?
Post Posted: Wed Jun 12, 2013 3:29 pm
shit 10 seconds after i posted this i recheck the fuses (now its not pissing down) and found a popped one,
Post Posted: Wed Jun 12, 2013 3:54 pm
Did the fuse fix the issue? Sounds like a lot of different systems for 1 fuse :?
Vehicle: '94 Sj413, 1.6 baleno convert
Post Posted: Wed Jun 12, 2013 3:56 pm
That's some weird symptoms for a popped fuse, its possible you still have an issue (if you haven't already fixed it with the fuse) somewhere there, I would still be checking earths and main battery cable just in case (I know you already have).
You might find 12v and ground with no load but with load if you have some bad connections there will be a bit of resistance there, dragging the voltage down.
Post Posted: Wed Jun 12, 2013 4:38 pm
Replaced the fuse and all is good again,
By the sounds of it some of the stuff on that circuit will earth back through the wiring and cause some really strange things to happen,
Think I must of gave the tail lights a bit of a hit when I reversed into a rock must have causes the short and popped the fuse.
Post Posted: Wed Jun 12, 2013 4:50 pm
Which fuse was it out of curiosity?
Post Posted: Wed Jun 12, 2013 5:08 pm
I think it was stop/tail....top row third from the left
Post Posted: Thu Jun 13, 2013 7:30 am
Have a look under the car near the fuel tank not sure if its just mine but there's a heap of joiners to concet the worig to the rear of the car... You might have a wire that's broken through and earthing out on the body you might have to drop the tank to get a good look.... Are you running led tail lights??? After market reverse light/s??
Post Posted: Thu Jun 13, 2013 8:01 am
Nah mate its all standard back there... I checked/seperated and retaped the loom and so far so good.
Thanks for the advice fella's
Users browsing this forum: Google [Bot], UBZ and 474 guests
