It is currently Sun Oct 04, 2026 3:21 am
Post Posted: Sun Jul 26, 2009 11:28 am
Hi Guys
I have a WT with 30's and a 1lt transfer. I still would like a bit lower gearing. Question is can i put 4.1s or 3.9s in my Wt axels. Which would give me near as stock gearing on the road ?
Thanks
Post Posted: Sun Jul 26, 2009 11:54 am
wb800 wrote:
Hi Guys
Thanks
I run 3.9s in my WT diffs, that should be pretty close i'd say.
Post Posted: Sun Jul 26, 2009 12:50 pm
NT 3.9 gears or whole centres will bolt into WT housings but 4.1 won't.
If you need more than 3.9 then you can buy aftermarket gears from www.lowrangeoffroad.com or fit vitara 5.12 front gearsets.
Vehicle: 07 vvt jimny
Post Posted: Sun Jul 26, 2009 6:12 pm
that website is awesome i didnt relized reduction gear where that cheap :D:D
$495 or somehting for 4.16.1 ithink it was to suit the 31" tyres and just do it your self install :D:D:D
Post Posted: Sun Jul 26, 2009 11:02 pm
4.1's will fit if you get them from a WT maruti. They run 1.3 axles and centres with 1.0L gearing.
Post Posted: Sun Jul 26, 2009 11:59 pm
you do realise you are only 100rpm different from stock at 100km/h?
3.9's from a NT would take you closest to stock (but you'll be revving 100rpm harder than stock at 100km/hr)
Any other gearset will have cruise revs way high - 3734@ 100km/h with 4.1 diff gears.
OR
you could put 6:1's in the transfer. with no other change, your cruise revs will run 3587, but your crawl will go from 34:1 to 88:1 :twisted:
Post Posted: Mon Jul 27, 2009 12:26 am
thats USD
navara on 33s. hopfully rear air locker soon
Users browsing this forum: Google [Bot] and 178 guests
