It is currently Tue Nov 03, 2026 3:29 pm
Post Posted: Sat Jun 22, 2013 5:29 am
There's 2 different F10a cambelts, is it possible to make a later motor accept the earlier cambelt just by swapping the pulleys or vice versa?
Also, what's the point of the second key on the cam pulley? Is there another mark I haven't seen or something, they're about 20* apart!
Thanks
Hayden
Post Posted: Sat Jun 22, 2013 7:13 am
Its quite common for Suzuki pulleys top have more than one keyway as they tend to be used on a number of different models.
Post Posted: Sat Jun 22, 2013 8:43 am
I had a few F10A motors in my last beast.
It is important if swapping bits around,
that ratio of cam to crank is 2:1 or it won't run for long.
So make sure you have matching sets.
I never had problems fitting either type to either engines,
but knowing Suzuki there could be more than 2 types.
Pretty sure I remember tensioners being the same, too.
Users browsing this forum: No registered users and 93 guests
