It is currently Tue Nov 03, 2026 8:18 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 10 posts ]
Vehicle: Zook
Post Posted: Mon Jun 24, 2013 2:34 pm
Top
For sale is my Warn hi mount winch.
All work done by Mal Leslie.
6hp motor with breather and coated internals to stop corrosion (motor approx 12 months old)
Breather on gearbox housing.
Oil fill and drain plugs.
Brace bars x2 between end plate and main housing.
Brake shaft tapped and bolted to prevent circlip coming off.
Free spool pinned to eliminate disengagement under big loads.
Had full service kit and seals approx 1.5 years ago.
Anodized aluminium fairlead (in new condition)
Genuine Albright solenoid.
x4 mounting bolts and nuts supplied.
Battery cables can be supplied if required with proper hex crimped terminals.
Providing you have a descent battery setup this winch pulls like a train. I have never been able to stall the motor or needed a double line pull regardless of the situation.
Does not come with rope however I can supply used cable.
Sold pending payment.
I can supply 40m of Supermax 10mm rope for an extra $400. This has been fitted to the drum around 3 weeks ago but never used and never been left out in the weather.
Contact me on here or my mobile 0419 874 654
Cheers,
Paul
Post Posted: Tue Jun 25, 2013 3:46 pm
Top
Have you got any pics ?
Vehicle: Zook
Post Posted: Tue Jun 25, 2013 5:45 pm
Top
Not on my camera however I have some on my phone.
Either sms me or pm me on here with your mobiel and I an send some through. It's still on the car at the moment so can't get you pictures from every angle.
Cheers,
Paul
Post Posted: Thu Jun 27, 2013 12:39 pm
Top
$2350?
Vehicle: Zook
Post Posted: Thu Jun 27, 2013 5:49 pm
Top
Junior_91 wrote:
$2350?
Yes, would you like to buy it?
Vehicle: 1994 Suzuki Sierra soft top
Post Posted: Thu Jun 27, 2013 6:16 pm
Top
Hahahahaha
Post Posted: Sat Jun 29, 2013 7:43 pm
Top
My highly modifed high mount only owes me 3K. So no thanks mate.
Vehicle: Zook
Post Posted: Sat Jun 29, 2013 8:45 pm
Top
No worries.
Move along then pal.
This winch has dragged an 80 series around with ease and I doubt your car would be heavier than that? Either way, some people may not be as fortunate as you to spend close to 3k on a winch. Even a stock standard hi mount (which this is not) is great on any zook, let alone this one which had had all of the weak points sorted (excluding break shaft) which is not an issue unless running 24v.
Cheers,
Paul
Vehicle: Zook Monster Truck
Post Posted: Wed Jul 03, 2013 4:10 pm
Top
put it on ya zook paul, you know you want to :)
Vehicle: Zook
Post Posted: Wed Jul 03, 2013 4:50 pm
Top
Was thinking about it Owen but it's now sold.
Users browsing this forum: No registered users and 16 guests
