It is currently Mon Sep 21, 2026 11:49 am
Post Posted: Fri Jul 05, 2013 2:03 pm
Anyone use them, reports good or bad, brands.
I want to raise my compression to around 11-1, there are a few ways, but high comp pistons would be the easiest, trouble is, the only ones I have found so far are pretty Exxy.
Set of quality con-rods, pistons n rings, bit over AUD 2,000, then still bearings etc.
Post Posted: Fri Jul 05, 2013 2:24 pm
The high comp pistons I used were from LROR.
Mart used YZ125 pistons I believe
Post Posted: Fri Jul 05, 2013 2:30 pm
Are they ok ?
Did you get what was expected from them ?
Im doing up my donk, the cam and springs are sitting at home, the head is in Adelaide being ported n polished with oversized valves and a 3 angle valve job. Have to get the cam to him to get it all matched is all.
Has been told to me, by head man, that if I want to get this running as good as it can, up compression to the 11 to 11.5-1 mark
Post Posted: Fri Jul 05, 2013 2:34 pm
Isn't yours a G16a?
Post Posted: Fri Jul 05, 2013 2:36 pm
yes, looking for high comp pistons on LROR site, only has 1.3 ones, or so I can find.
Post Posted: Fri Jul 05, 2013 2:41 pm
Yeah, Josh had a 1.3. I can't see any G16a high comp stuff either.
Vehicle: SWB Sierra
Post Posted: Fri Jul 05, 2013 2:45 pm
How much compression could be gained by skimming the head, if any at all?
Have a look on redline, they should have a few threads about high comp pistons.
Vehicle: Suzuki
Post Posted: Fri Jul 05, 2013 2:46 pm
Off topic but how much roughly did it cost to get the head work done as I'm thinking of doing some head work to mine
Post Posted: Fri Jul 05, 2013 2:51 pm
Hant been done yet, have to get the cam to them, but a basic port and polish, reseat valves is around 400, a told the G series heads are a bad performer, and a port and polish really livens them up.
Mine all up will be over the grand mark id say.
Post Posted: Fri Jul 05, 2013 2:52 pm
My understanding is, very little, have been known to be wrong now and then but.
This is why Im going down the high com piston road, would love to think its just a shave, wonderfully cheap by comparison.
Post Posted: Fri Jul 05, 2013 2:54 pm
Send the whole lot to Tony at Knight Engines, for a complete build rather than get the head done at one spot & the bottom end at another.
The dude is a genius!!!
Post Posted: Fri Jul 05, 2013 3:11 pm
Got him, ringing now
Post Posted: Fri Jul 05, 2013 3:13 pm
Will be money well spent, I can guarantee you that.
Post Posted: Fri Jul 05, 2013 3:21 pm
costing a bucket load now, in for a penny in for a pound.
May take the car over and have someone fit the big carbs as well.
Thatd be reeeeel nice, should make lots of brooom then.
Post Posted: Fri Jul 05, 2013 3:35 pm
Honda guys use G16 pistons to lower compression in their Turbo Vtec Yo! things, perhaps some kind of Honda piston will work?
Vehicle: 1995 2.0V6 Vitara LWB
Post Posted: Fri Jul 05, 2013 3:36 pm
wonder if 4x's FCR40's would make a big difference?
Post Posted: Fri Jul 05, 2013 3:39 pm
Tony will sort you out!
If you're going to invest that much in it it'd be worth getting Tony a G16b or G13b (as well as your G16a) head to compare which has the most potential. I'm sure you could pick up a cracked G16b head for next to nothing. Just to compare G16a and G16b would be very interesting and could pick you up a number of ponies. But who knows, you could find the G16a head has more power potential.
Post Posted: Fri Jul 05, 2013 3:55 pm
I'd just use the twin 40mm DCOE's he's got for it!!
Tony won't be cheap but will be money well spent. Will be interesting to see what he does to the top end.
I'm assuming you're having the bottom end fully build seeing you're looking at pistons?
Post Posted: Fri Jul 05, 2013 4:17 pm
Might be worth a read
http://www.pirate4x4.com/forum/suzuki/6 ... heads.html
Post Posted: Fri Jul 05, 2013 4:41 pm
Ahh, sorry I'm a noob.
I had my entire head rebuilt (down to replacing the rocker rods) and it cost $380
Post Posted: Fri Jul 05, 2013 4:46 pm
Be a waste of money if I didnt hey, all it would be is a hand grenade.
I want to not only get there, but most importantly, get back.
Post Posted: Fri Jul 05, 2013 4:53 pm
was it ported & flow tested? as that's where the man hours & dollars go, a simple recon & freshen up is usually pretty cheap.
seeing SuziBlu has gone all out with carbs & cam etc, might as well build the rest to suit.
some of Tony's work can be seen here:
http://performanceforums.com/forums/sho ... ght=merlin
http://performanceforums.com/forums/sho ... highlight=
Years ago he build a motor for a friend and it was just pure awesomeness, still gets around today & hasn't been touched since it was bolted into the car.
Post Posted: Fri Jul 05, 2013 5:31 pm
This is one of my favorites of his.
http://performanceforums.com/forums/sho ... f-the-game
Post Posted: Sat Jul 06, 2013 2:13 am
just had a read of that thread, some great info in there. 8)
Post Posted: Thu Jul 11, 2013 12:19 am
hahaha that's crazy, hows the dedication to the cause! 8O 8)
this is very similar to the one he screwed together for my mate years ago, L24 monster in a datto 1600 with twin webers, though this one is fuel infected.
http://performanceforums.com/forums/sho ... 56k-LOL%29
Users browsing this forum: Google [Bot] and 144 guests
