It is currently Sun Sep 20, 2026 9:58 am
Post Posted: Fri Jul 05, 2013 3:24 pm
Hey guys,
My Sierra is running 31s with standard gearing, to make it a bit more driveable till I get some 6.5 gears In my transfer can it handle being driven about 20km a day (work and back) with hubs unlocked and in low range? Or will I burn something up.
Cheers.
Post Posted: Fri Jul 05, 2013 3:29 pm
Even at max speed in low you will piss off every other motorist stuck behind you.
A sierra is drivable enough with 31's for road only use. Don't use 5th and you'll be ok.
Post Posted: Fri Jul 05, 2013 3:31 pm
thats gonna be like driving around in third gear when your in 5th low.
um no
Vehicle: 1995 2.0V6 Vitara LWB
Post Posted: Fri Jul 05, 2013 3:38 pm
dont forget to factor in a 60kmph max speed at about mid revs top gear
Post Posted: Fri Jul 05, 2013 3:43 pm
This.
Vehicle: SWB Sierra
Post Posted: Fri Jul 05, 2013 3:52 pm
I would ride my pushie before driving to work in low range.
Online
Post Posted: Fri Jul 05, 2013 3:53 pm
um no
A WT in low range actually has higher gearing than an LJ50 in high range. :lol:
It'd actually be kinda usable though, with 31s that works out at about 4500 rpm at 100 in 5th low. Seriously just stick to high range and don't use 5th though.
Post Posted: Fri Jul 05, 2013 5:59 pm
It's max 70kph to work just wondering if I need to (ie quicker off the line) will it harm anything. I'm not familiar with zooks normally drive a patrol ; )
Post Posted: Fri Jul 05, 2013 6:59 pm
It wont do any harm. But its not a good idea
Post Posted: Fri Jul 05, 2013 7:44 pm
Righteo cheers all
Post Posted: Fri Jul 05, 2013 8:37 pm
Had my Sierra for around 15 years.
Due to back and leg issues, I often used low ratio in peak hour traffic with front hubs unlocked,
never noticed any bad effects.
Users browsing this forum: No registered users and 128 guests
