It is currently Mon Sep 21, 2026 5:37 am
Vehicle: Suzuki jimny, WT sierra, GTR.
Post Posted: Fri Jul 05, 2013 12:13 pm
Hi Guys,
I seem to be having a problem with a loud noise in the rear of my jimny under flex. It is a very lound clang, and sounds spring related. Im running ultima shocks with tough tog springs.
Does anyone else habve this problem or know how to fix it?
Any help would be appreciated as the noise is quite off putting on the trails!
Andrew.
Post Posted: Fri Jul 05, 2013 12:24 pm
Mine click when it flexes
Post Posted: Fri Jul 05, 2013 12:33 pm
Pretty normal from my experience.
Post Posted: Fri Jul 05, 2013 12:39 pm
x2 on it being pretty common, some pics n shit in these threads. have a suss of the lower spring seat on the rear diff & where the spring sits.
viewtopic.php?f=5&t=35282&hilit=jimny+spring+seat
viewtopic.php?f=4&t=22123&p=394853&hilit=jimny+spring+seat+coil#p394853
Vehicle: Coil Sierra
Post Posted: Sat Jul 06, 2013 7:05 am
Asps91 wrote:
Hi Guys,
Andrew.
When the lift was installed did you loosen all of the control arm bushes and let the car sit for a while then tighten?
I read somewhere that procedure helps after installing a lift to coil spring 4wd's.
You also might have a loose bolt on the control arm bushes, this will give off a snap sound apposed to a clang sound.
Post Posted: Mon Jul 08, 2013 9:00 am
I will have a look next time I go for a play, I'm going to try and catch it on my go pro. I do have a feeling that the springs are unseating.
Users browsing this forum: No registered users and 161 guests
