It is currently Sat Aug 01, 2026 9:46 pm
Vehicle: LWB sierra
Post Posted: Fri Jul 12, 2013 12:25 am
Just stripped the back axles down on the 87 sierra and each axle had 2 wheel bearing spacers. It went spacer, bearing, spacer, retainer. Is this normal? The manual only shows one spacer and I understand some kits now come with a bearing that has a permanent spacer already on there?
By the looks of it the kit I have coming has no spacers at all? :?
One side also had an oil seal protector, the other side did not... How important are these as the kit also looks like it does not have the oil seal protector.
Cheers,
Hamish.
Post Posted: Fri Jul 12, 2013 12:56 am
Just order the bearings that suit your vehicle. WT's run a bearing with an offset inner race, which acts like a spacer.
As for the seat protector, they are not supplied with ANY bearing kits. They are a genuine only part. If you lube yur seal and wipe your axle down with oil, and are very carefull, you should be able to get the axle in without damaging the seal.
Vehicle: LWB sierra
Post Posted: Fri Jul 12, 2013 1:11 am
I ordered the bearings for a SJ50 (NT), they have not arrived yet but the picture on the website has no spacers... I have already cut the old bearings and spacers off the axles so I hope I ether don't need them or the picture is wrong. I was just not sure what was normal.
So the oil seal protector is just to protect the seal when you are re-installing the axles, nothing more?
Post Posted: Fri Jul 12, 2013 5:12 am
You will need a spacer on each axle if you run NT bearings.
If you fit WT bearings you don't fit the spacer because it is built in to the bearing inner race.
Depends how bad you have hacked them (spacers), they may be reusable even with a cut through them.
Vehicle: LWB sierra
Post Posted: Fri Jul 12, 2013 12:24 pm
Just went and found the old outer spacers and they are not cut to bad so I will reuse them, The inner ones and in bits but I will try without...
So WT bearings fit NT axles? If so I will buy them next time.
Post Posted: Fri Jul 12, 2013 2:27 pm
Some kits come with the spacer built into the bearing. Others i've seen with a seperate spacer.
Post Posted: Fri Jul 12, 2013 4:00 pm
WT bearings with the built in spacer are approx twice the price of NT bearings so it pays to reuse the spacer rings.
Vehicle: WT sierra, GU CRD
Post Posted: Fri Jul 12, 2013 4:31 pm
So could it be worth it to track down some spacers to use in a WT? I need to do this job as well.
I love ZD30. :)
Post Posted: Fri Jul 12, 2013 5:27 pm
Put it this way... I don't buy WT bearings. :D
Post Posted: Fri Jul 12, 2013 7:26 pm
4wd products sells NT wheel bearing kits for $69 delivered and includes seal protectors and spacer rings.
Like jas does, I have just brought a NT set for my WT diffs (the WT kit is $120) I ordered it yesterday at midday and it was on my doorstep when I got home from work this arvo.
http://pages.ebay.com/link/?nav=item.vi ... 0984179748
Post Posted: Fri Jul 12, 2013 7:39 pm
I got wt bearings from Repco not long ago for $35 each kit includes offset bearing the reatuner and oil sea I think it was... and from a bearing place it was about the same
Users browsing this forum: Google [Bot] and 1107 guests
