It is currently Sun Aug 02, 2026 11:59 pm
Vehicle: 2003 Grand Vitara
Post Posted: Tue Jul 16, 2013 4:26 pm
Just have a quick question in regards to a Treg Hitch. I may be purchasing a camper trailer in the coming weeks that is fitted with a Treg Hitch. Being a noob I only have a standard 50m ball attached to my tow bar and I'm guessing a Treg Hitch won't couple to it.
What do I need to change on my tow bar to get it to work and where can you buy them from?
Thanks for the help
Josh
Post Posted: Tue Jul 16, 2013 4:57 pm
Looks to me like you undo and remove your 50mm ball and bolt the hitch on.
Post Posted: Tue Jul 16, 2013 5:18 pm
correct :wink:
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Wed Jul 17, 2013 9:24 am
its a bit taller than the 50mm ball so check your clearance on your tow ball to your door so it clears as you open it. my tow-bar is so high i have to remove the hitch from the receiver to open the rear door :(
Vehicle: 85 ' Drover
Post Posted: Wed Jul 17, 2013 9:52 am
Are treg hitches supposed to be pretty good?
They seem to be considerably cheaper than the "ozhitch" i was looking at.
Vehicle: Jimny 99 2" lift, 31s etc
Post Posted: Wed Jul 17, 2013 10:13 am
Have you tried flipping the hitch and flipping the tow ball the right way up, lowers it normally by about 100mm
Post Posted: Wed Jul 17, 2013 10:29 am
that was the reason why i went with the ORAC hitch instead, but even then i reckon i'd just have enough clearance for the TREG hitch.
yep can be done, but if you've built a trailer to sit level & match the hitch height it's going to throw the lot out.
Post Posted: Thu Jul 18, 2013 7:10 am
Thanks for the response
Post Posted: Thu Jul 18, 2013 7:55 am
My poly block hitch has the trailer sitting at the same height as it did with a ball hitch however the actual hitch is lower so I can now open the GVs rear door when the trailer is connected.
Vehicle: Daisy
Post Posted: Thu Jul 18, 2013 7:34 pm
Since we've turned this thread into what hitch do you have, I'm going with a combination pintle hook and tow ball. It's probably going to be louder than the hitch mentioned at the top but I reckon it's going to be just fine.
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Fri Jul 19, 2013 9:38 am
mines flat out just too high :P
Post Posted: Fri Jul 19, 2013 10:18 am
^^^ just get a drop receiver hitch.
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Fri Jul 19, 2013 12:42 pm
i was going to ask if these existed, then i did a atari and just searched myself pompoms
good call by the way, might have to get 2, because im to lazy to replace the treg with a ball every time i want to tow the boat.
http://compare.ebay.com.au/like/3508291 ... 0829106761
Users browsing this forum: No registered users and 91 guests
