Joined: Thu Jan 19, 2012 8:48 am Posts: 73 Location: Victoria
Vehicle: 1995 suzuki sierra hardtop
Posted: Sat Jul 20, 2013 5:08 pm
Hey Guys,
I've just swapped in my gti motor into my sierra, atm its running (roughly) but I have a 3 wires in the new loom not yet connected. 1 is a black/yellow wire, C1 pin on the ECM called the start signal atm it's not connected is this right? The other 2 are the wires from the alternator plug, atm I have the alternator connected to the old loom plug (original sierra one) and not the new loom (swift gti one) would this effect anything? Should I connect it to the new loom or join both the looms?
Joined: Sun May 04, 2008 11:30 pm Posts: 9716 Location: NSW
Posted: Sun Jul 21, 2013 9:46 am
Starter, I connected the signal for mine for G16b Baleno. Used sierra standard wire, but joined onto the Baleno harness for the ecu. Not sure if its needed, but may as well. 1 wire.
Alt, i used sierra harness but added a fuse for the main battery charge circuit. I used the sierra wires as it goes straight to the light on the dash. Think i deleted the Baleno wires.
Users browsing this forum: Google [Bot] and 94 guests
