It is currently Mon Nov 02, 2026 12:16 am
Post Posted: Mon Jul 22, 2013 8:14 am
I have some remote trips planned and am in the process of putting together a spares kit. What are common things that go wrong? So far I have spark plugs, belts and a coil. What else should I get?
Post Posted: Mon Jul 22, 2013 11:54 am
Id get a spare sensor of everything.
I also have a bonnet if you want it
Post Posted: Mon Jul 22, 2013 4:48 pm
No problems. I will be down your way twice in the next few months, would be good to drop into yours for a chat :wink:
Post Posted: Mon Jul 22, 2013 4:54 pm
Let me know beautiful
various sized vicon o-rings for fuel pump connections that decide to split on ya........ :oops:
lower shock bolts
kingpin maybe?
MY BUILD THREAD HERE!!!!!
Vehicle: 2011 jimny
Post Posted: Mon Jul 22, 2013 5:13 pm
from past experiences a set of radiator hoses would be handy
Vehicle: 2012 jimny
Post Posted: Mon Jul 22, 2013 5:15 pm
spare undies due to the 84 angry stallions jammed into the 1300cc of pure fury.........
Post Posted: Mon Jul 22, 2013 5:17 pm
Mine will be a bit more then that. Armsup
Vehicle: 2012 jimny
Post Posted: Mon Jul 22, 2013 5:26 pm
what motor you going for? after my last long distance trip ive decided to go bigger but dont know what motor. sorry for the thread hijack.
Post Posted: Mon Jul 22, 2013 5:52 pm
Not bigger, just better.
Vehicle: Suzuki Jimny 2009
Post Posted: Mon Jul 22, 2013 7:20 pm
I have, or intend to get eventually, the following:
King PIN bearings and some spare shims
Hoses (there are three of them)
Cam angle sensor
Belts
Fuses
Spare suspension arm and shock absorber bolts
Wheel bearings
Oil plugs for diff
This is all the main small stuff. Cam senor is the most expensive of these.
If you really get serious and have room then a left and right CV joint but that depends on what tyre size you now have.
Post Posted: Mon Jul 22, 2013 7:43 pm
Add a crank angle sensor to that list. I had one fail on my M18A and apparently it is a common M series problem. See viewtopic.php?t=37131&p=679728
Post Posted: Mon Jul 22, 2013 8:41 pm
Spare gear box
Post Posted: Mon Jul 22, 2013 8:45 pm
Haha^
Yeah the shock and trailing arms bolts come loose a bit on jimny rear ends for some reason... Maybe some loctite and some bolts.
Vehicle: 2012 Jimny
Post Posted: Mon Jul 22, 2013 10:27 pm
lower shock bolts
kingpin maybe?
+ 1 to the shock bolts, I lost mine last time I went out haha
Maybe some bearings or CVs?
Post Posted: Tue Jul 23, 2013 7:20 am
can always get home without cv's.
definatley some kingpin brgs and shims though +1 to crank sensor, i got a sparey in my glovebox from troubleshooting the fuel pump the other year.
if u dont have rad hoses tapes enough to get out of trouble.
change belts as service and hang on to old ones
basic shit that im sure you alrdy know shep, mainly putting up for other readers.
oh i dont think you'd have a cam angle sensor in your engine like mike suggests, could be wrong, but pretty sure they were only in the early Jims, even earlier than mine. crank is the problem child as Tim suggests.
Post Posted: Tue Jul 23, 2013 5:17 pm
I meant the crank sensor but wrote cam sensor, sorry, but yes it is something that you can't work around.
Post Posted: Wed Jul 24, 2013 7:36 am
Definitely Crank and Cam sensors, apart from that just regular outback spares (hoses, fuses, belts etc.)
I overcame my shock bolt loosening by adding two large washers on the outside of the bush so the movement of the axle can't turn the bolt, grease between them to help them rotate
Users browsing this forum: Google [Bot] and 46 guests
