It is currently Mon Sep 21, 2026 2:44 am
Post Posted: Sat Jul 13, 2013 12:17 am
Made up my own brackets for my Jimny to take the Sierra transfer case
Machined out the factory Jimny sensor pick up wheel thing and attached it to the output flange
Picked up a few extra mounting points, all from 5mm plate
Powder coated it all black
Mounts the transfer forward 25mm so the Sierra front shaft fits in the rear easier, it also allows more room for the front haft over the gearbox crossmember. The case also sits 20mm higher.
Will put up better shots and more info soon
Kyzer
Post Posted: Mon Jul 15, 2013 5:13 pm
Nice work as usual. I can see a new standard for kit choice.
Did you consider joining the mounts to make a cradle, as popular with Sierras running very low gears.
Vehicle: Sj70 tintop
Post Posted: Wed Jul 17, 2013 7:43 pm
great write up mate.
Post Posted: Mon Jul 22, 2013 9:34 am
I did but I wanted to get the transfer out without taking the exhaust off which meant taking off the passengers side mount and bracket while in the car.
At present I've fitted up this kit to my car and will be driving it soon
ATTN: To make them as kits I need another Sierra transfer (blown or Brocken) to put in my jig, as the one I used is now bolted under my Jimny. I am also considering drawing the whole thing up in CAD and just putting it here
Kyzer
Post Posted: Mon Jul 22, 2013 10:24 am
Awsome work as usual mate.
For the unedumekated like myself benifts of putting a sierra case into a Jimny?
Dave
Post Posted: Mon Jul 22, 2013 10:29 am
instant reduction gearing + the ability to use sierra transfer gears for more reduction
Post Posted: Mon Jul 22, 2013 12:18 pm
sierra case is also gear driven instead of chain which slips once worn or under high load.
Vehicle: Suzuki jimny, WT sierra, GTR.
Post Posted: Tue Jul 23, 2013 1:49 pm
Wow, are you going to reproduce these mounts any time soon. Would prefer to buy local than from ora!
Post Posted: Fri Jul 26, 2013 10:10 am
I just need another transfer (if someone has a stuffed one) to put in my jig to trial fit brackets
Kyzer
Post Posted: Fri Jul 26, 2013 11:16 am
Can't help you there but I'm sure someone here has one lying around that they could donate to a worthy cause!
Users browsing this forum: No registered users and 41 guests
