It is currently Sat Aug 01, 2026 11:18 am
Vehicle: 2000 Jimny
Post Posted: Sat Jul 27, 2013 4:05 pm
I am away from my Jimny and need to know 2 things:
1. What is the width of the bonnet?
2. Is the 2013 bonnet a direct fit for a 2000 model? (my answer is no)
Post Posted: Sat Jul 27, 2013 4:16 pm
definite no to Q.2
Vehicle: 2000 Jimny
Post Posted: Sat Jul 27, 2013 4:42 pm
Had a mate that said it was possible and I said it won't fit due to the change in shape with the new model.
I had an idea for my bonnet (no, its not a scoop) but need to know the bonnet width.
Post Posted: Sat Jul 27, 2013 4:49 pm
front guards & grill are different enough that it wont line up without swapping the whole front clip.
The scoop is not open at all, totally blanked by plastic
The entire front clip is different, but inner guards and firewall backward is the same.
The new Jimny clip is too bulbous for my liking but the separate grill is cool. The bumper would bolt straight onto mine I think but wouldn't trim-up very nicely.
Brackets have been added to support the taller guards and bonnet
Vehicle: Suzuki Jimny 2010
Post Posted: Tue Jul 30, 2013 6:36 pm
I reckon it'd be possible to fit the newer bonnet to the older version, but you're gunna need that front grill too
Post Posted: Tue Jul 30, 2013 6:37 pm
^^^^^ I have no proof to back this up, just a thought
Post Posted: Tue Jul 30, 2013 6:43 pm
and front guards :wink:
have a look at all the panel work on the corner above the headlight on the new shape compared to the old shape.
also shown here, there is a riser section for the bolt holes & a plastic trim panel to fill the gap from the inner guards to the new outer guard, without the guards the bonnet would be sitting proud from everything else.
Post Posted: Tue Jul 30, 2013 6:45 pm
Not bad for a Vitara driver :thefinger:
:rofl: :rofl: :rofl: :rofl: :rofl:
Guess I'll just buy a ghey bonnet scoop one day :(
Post Posted: Tue Jul 30, 2013 6:53 pm
it's all about the attention to the minor details :wink:
Vehicle: 2000 Jimny
Post Posted: Tue Jul 30, 2013 7:22 pm
As long as it is functional and not just for looks
Post Posted: Tue Jul 30, 2013 7:34 pm
like wetting spark plugs when doing water crossings & washing the car. pompoms pompoms
Vehicle: 2000 Jimny
Post Posted: Tue Jul 30, 2013 7:37 pm
They are going to get wet when fording ;)
Post Posted: Tue Jul 30, 2013 7:43 pm
you'd be surprised how dry the engine bay say when fording, it's only when you stop that it becomes a real problem... apart from when you've got a funnel on your bonnet aimed directly in the flow of water if it comes over your bonnet & dumping on top of the coil packs etc. :wink:
Post Posted: Tue Jul 30, 2013 7:44 pm
Glad you passed all that on, saved me going digging.
____________
I think the bonnet would bolt up and may even latch properly but as Atari said there'd be a gap all the way up the sides.
Post Posted: Fri Aug 02, 2013 9:31 pm
You'd be pretty hard pressed to wet them unless you were sitting still in the water... There's a cover plate over them with a seal under it. Not saying its impossible but not easy either.
Oh and FYI... I don't have any intentions currently to put one in... I have thought about it though to stop everything melting inside the engine bay.
Post Posted: Sat Aug 03, 2013 7:25 am
servo operated opening flap in the scoop, best of both worlds ;)
Vehicle: 2000 Jimny
Post Posted: Sun Aug 04, 2013 3:44 pm
So can anyone measure up the width of their bonnet please?
Post Posted: Mon Aug 05, 2013 7:03 am
which jimny model do you want the width measurements? Mine is pre-facelift.
corner to corner closest to the windscreen = 1290mm exactly
where the bonnet bends to go down to the bumper = 1190mm
Vehicle: 2000 Jimny
Post Posted: Mon Aug 05, 2013 11:51 am
2000 model bonnet :)
Cheers Zuke
Users browsing this forum: No registered users and 79 guests
