It is currently Fri Nov 13, 2026 1:46 pm
Vehicle: 92 Suzuki Sierra
Post Posted: Fri Apr 19, 2013 12:41 am
COLEMAN Dual fuel Lantern with original box $35
Probably only used once in since new, approx 15 years old, runs on petrol or coleman fuel (turps) still has $125 price tag on retail box and has a packet of gas mantles
COLEMAN Dual fuel twin burner stove $75
Clean, near new nly used a handful of imes. Petrol/Coleman fuel
80L Lemair mini fridge $50
(twin crisper suit single bachelor or as a bar fridge)
New 800w Inverter (used less than 5 minutes Modified sinewave) $50 posted australia wide
NEW/NOS G13 8v STD 74mm Flat top pistons NO RINGS (4x) $40 posted (can include used sierra rods with extra used pistons $10)
Update. I have 4 G13 8v heads and 3 engine blocks (1x G13A, 1x G13BA, 1x G13B)I you need any components or parts (eg rods, valves, complete heads, bare block etc ) for 8v 1.3L shoot me a PM. They are free providing you pick it up or pay for postage i can't bare to scrap useful parts.
The exception is the g13b forged crank which will need machining but is $20
Suzuki baleno multi-rib altenator, 55A (suit g16 engines) $20
Suzuki Vitara V6 LWB Disc/rotors to suit 16" wheel $100 --> NOW $80
140A Cigweld stick welder $60 including 20 weld rods
(needs electrode holder which are $15 on ebay or at bunnings, can supply a new Cigweld one for $36)
2x black ninja swords $35 for the pair plus post
Pick up northern beaches, sydney. Post at buyers expense (3kg prepaid satchel?)
Seth 0414810942 or PM me here
Post Posted: Wed Apr 24, 2013 11:01 am
bump, added timing light ($25 posted)
Post Posted: Thu Apr 25, 2013 5:29 pm
merge my stray items, will be adding to it rather than starting new threads all the time
Post Posted: Thu Apr 25, 2013 5:49 pm
timing light, dwell tacho, compression gauge sold pending payment. If you where interested in it just send me a pm and i will put you in queue if falls through.
Post Posted: Thu Apr 25, 2013 6:12 pm
added the 2nd largest swiss army knife in the world, the largest is the Wenger Giant.
Post Posted: Tue May 07, 2013 6:30 pm
XAVT now on ebay
http://cgi.ebay.com.au/ws/eBayISAPI.dll ... 843wt_1137
140A Cigweld welder with 20welding rods $65
needs electrode holder, can supply one to test unit.
Post Posted: Thu May 23, 2013 11:02 am
added v6 vit brakes
Post Posted: Fri Jun 21, 2013 5:41 pm
Added: Genuine Maglite with Led Upgrade.
Gives a nice clean white light, has spare incadescent in the buttstock which you will probably never need since the led is rated 20 000 hrs.
Takes 2x C size batteries. Recommend you get the AA->C batteries adaptor off ebay so you can just use AA rechargeables. With 2xAA 2000mah in adaptors i have got a recorded 27 hours run time... much better than the factory 3 hour weak light incadescent!
$22 posted australia wide
Post Posted: Sat Jun 22, 2013 6:11 pm
Added:
Snap-on Gm70M 1/4" ratchet + 2 extension bars (150mm + 50mm) $35 posted australia wide
Post Posted: Fri Jul 05, 2013 7:33 pm
G13/g16 8v sports exhaust system. Complete Extractors+Catconverter+muffler to suit Sierra 1.3l models (fits both 1.3/1.6l engines) $100. Armsup
Cheaper than getting just the extractor neew on ebay.. less mucking around just bolt in! :peaceout:
Post Posted: Sat Jul 20, 2013 3:08 pm
Added 12v battery charger (mains 240v)
Post Posted: Sat Jul 20, 2013 4:14 pm
added photos of exhaust system
Vehicle: 1991 Vitara SWB
Post Posted: Sun Jul 21, 2013 9:30 am
Any chance of posting the exhaust+extractors to 3109 melbourne
Post Posted: Sun Jul 21, 2013 1:10 pm
Find a freight depot that is within 10kms of brookvale, Sydney nsw 2100 and I will drop it off to them if their quote works out for you. Haven't got time to do the leg work myself.
Post Posted: Sun Jul 21, 2013 2:03 pm
I'll do some ringing.
Can you give me the weight and approx length of the separated pieces?
It does fit a 1.6 vitara right?
1.6 carby vitara...?
Post Posted: Sun Jul 21, 2013 5:26 pm
Yes, it will fit yours
Post Posted: Sun Jul 21, 2013 5:28 pm
Awaiting pm reply too Santos :wink:
Post Posted: Sun Jul 21, 2013 5:43 pm
Its welded all in one piece. The extractors would fit a vitara. If I cut it up you could probably reuse the all parts to make an exhaust system with new pipe that will suit a vitara. If that's your intention I will go get the measuring tape. As one piece now I have no idea if it would line up under a vitara :?
Yeah just need to get my camera and stuff, thought I send you some 'extra' photos of stuff. :P
Post Posted: Sun Jul 21, 2013 5:53 pm
It'll have no chance of fitting a Vit as it is. Better off just sending extractors, cat and muffler
Post Posted: Sun Jul 21, 2013 6:59 pm
Rough measurements final value is thickness and are estimates
Extractors 60cmx60cm x20cm
Muffler 60cm x25cmx 25cm
Cat-converter 35cmx20cmx20cm
If I cut it up I could probably fit it in a box that will go through auspost.
$52.30 is the biggest box with 20kg using online estimator. The max they will post. I don't think It will weigh that much but I can stand on scales tomorrow holding it to get the weight.
Post Posted: Wed Jul 24, 2013 11:21 am
added spring bush kit
Snapon-1/4ratchet+bars & 3d Maglite SOLD
Post Posted: Wed Jul 24, 2013 12:18 pm
Would you sell the extractors separetly ?
Post Posted: Wed Jul 24, 2013 2:59 pm
sure $80 and I will cut it for free :sup:
Post Posted: Thu Jul 25, 2013 3:31 pm
added photo of Stick welder
Vehicle: 92 suzuki sierra 02 f250
Post Posted: Fri Jul 26, 2013 9:37 pm
Hi santos
I'll get the battery charger off ya if you still got it
Cheers mate
Post Posted: Sat Jul 27, 2013 6:05 pm
complete 8v sport exhaust system sold.
Post Posted: Tue Jul 30, 2013 4:27 pm
Pm sent
Post Posted: Sat Aug 17, 2013 3:47 pm
bump ADDED FREE STUFF
Post Posted: Tue Aug 20, 2013 9:57 pm
new old stock pistons + rings $80posted
