It is currently Mon Nov 02, 2026 2:38 am
Vehicle: sj70 sierra
Post Posted: Wed Jul 24, 2013 6:32 pm
EDIT: forgot to mention a had to by 20 meters of the stuff and now have heaps left, if someone want to come and pick some up to make one for themselves feel free, i live at Terrigal, NSW
Was looking at making PVC snorkel because it suited my low budget, however i had heard some bad things about them such as exploding when hitting trees etc. Instead.. i did something cheaper but potentially more dodgey and went and bought some agg pipe from Bunnings. this is the result..
Just zip tied it to my light bar and added another 2 to put an angle on it to keep the rain out. put same mesh over the top to keep out anything else that might want to get in there
Post Posted: Wed Jul 24, 2013 6:47 pm
I wouldn't have snipped the tag off the cable ties cos then they would look proper dodgy.
Post Posted: Wed Jul 24, 2013 6:53 pm
haha, how bout i glue them back on?
Post Posted: Wed Jul 24, 2013 6:56 pm
As far as dodgey snorkels go it doesn't look too bad! How is it attached to the A pillar?
Post Posted: Wed Jul 24, 2013 7:02 pm
haha thanks. It's just held on with a cable tie around my light bar :oops: but i suppose it also means it wont damage anything if it gets ripped off. Was thinking of putting a couple of dabs of sikaflex down the A pillar to stop it moving around
Post Posted: Wed Jul 24, 2013 7:12 pm
where it goes through the inner guard, get some vacuum hose & run a cut along the length of the hose & slip it over the over the hole you cut in the metal so it's not going to wear a hole in the tubing.
Post Posted: Wed Jul 24, 2013 7:18 pm
good idea, i ran i good bead of sikaflex around it but vacuum hose would probably work better
Post Posted: Wed Jul 24, 2013 7:33 pm
Haha :goodjob:
Is the pic still around of the one with a dolphin torch snorkel hat ?
Post Posted: Wed Jul 24, 2013 7:34 pm
i'll get my grimbo on boss :wink:
Post Posted: Wed Jul 24, 2013 7:36 pm
viewtopic.php?f=14&t=6427&p=84637&hilit=dolphin+torch#p84637
Post Posted: Wed Jul 24, 2013 7:40 pm
hahaha thats awesome
Vehicle: Suzuki Stockman '85 1litre
Post Posted: Wed Jul 24, 2013 9:41 pm
Brilliant
Post Posted: Thu Jul 25, 2013 12:26 am
Nice! I used vacuum cleaner hose (dyson kewality) on my 1ltr! As long as it works!
Vehicle: Jimny 99 2" lift, 31s etc
Post Posted: Thu Jul 25, 2013 7:51 am
How's it attached to the pillar?
Post Posted: Thu Jul 25, 2013 12:22 pm
Post Posted: Thu Jul 25, 2013 12:24 pm
its not the Agg pipe with the slots all the way up it for drainage is it???
Post Posted: Thu Jul 25, 2013 12:50 pm
hahaha no, you can get it un-slotted too
Vehicle: Vit
Post Posted: Sun Jul 28, 2013 8:11 pm
Good job mate!
Vehicle: Vitara 1990 SWB Soft Top
Post Posted: Mon Jul 29, 2013 9:28 am
Have you disabled or plugged up the warm air inlet on your air cleaner. Defeats the whole purpose if it can still get a gut-full of water from there.
Post Posted: Mon Jul 29, 2013 2:43 pm
yep, siliconed that sucker shut
Post Posted: Tue Jul 30, 2013 4:01 pm
What's the warm air intake for anyway, I always thought the colder the air in the better
Post Posted: Tue Jul 30, 2013 4:20 pm
It helps the motor warm up in places that experience very cold temps.
Vehicle: sj51
Post Posted: Tue Jul 30, 2013 4:47 pm
works great too.. i manually switch mine onto the winter setting...................................................... in winter
Post Posted: Tue Jul 30, 2013 5:02 pm
someone told me its only purpose was to stop the carburettor icing up when its very cold, pointless in Australia
Vehicle: Ford Maverick 4.2 Diesel
Post Posted: Sat Aug 03, 2013 4:37 pm
love this!!!! love the dolphin in atari's photo better!!!
Post Posted: Sun Aug 04, 2013 2:39 pm
Not really. It doesn't have to be below freezing to ice a carb - Ice will form below about 2-3˚C, all the more so with fuel acting as a cooler.
Post Posted: Mon Aug 05, 2013 6:52 am
I have aggi pipe on mine! It's the best! Can lean over on it and it pops straight back out! I had used PVC it explodes and exhaust steel just crumbled under pressure.
Post Posted: Mon Aug 05, 2013 6:58 am
Haha yes! Go the agg pipe! :peaceout:
Vehicle: 1984 SJ410
Post Posted: Sun Jul 31, 2016 11:26 pm
Here in Java Indonesia, the only pipe like that black one you guys use is Toilet Poop Pump Out Pipe & it very strong for bashing thru the jungles here& is very recognizable as poop pipe...it is Very Bright Light Blue. My mate has made & fitted it to His LJ80 & now he has a new nickname & so does his rig. Bahahahahaha !
 Profile YIM
Post Posted: Sun Aug 07, 2016 7:13 am
Hahaha that's awesome!
Users browsing this forum: No registered users and 3 guests
