I was just wondering if anyone knows if a rear Coily centre (the actual casting has 2 lugs cast into it) can be used, or will fit in a front WT diff housing.
I already have 3.9 ratios so that part is not an issue, I have a rear air I want to put in the front with a set of 26 spline CV axles, and I would like to just pull centre out of my rear and bolt straight into front housing.
Then use the front centre in the rear housing.
If anyone can shed some light on this I would appreciate it.
David
_________________ Zuki
Suzuki Sierra 1990 Hardtop
Now just drive i
Users browsing this forum: No registered users and 636 guests
