It is currently Sun Aug 02, 2026 6:29 pm
Vehicle: V6 autolocker rear and so much
Post Posted: Sat Aug 17, 2013 8:15 pm
For some weird reason that makes no sence too me :?: My gear selector in a Auto 1995 Vitara is stuck in Park, drove it all day making well over 5 stop's with no problem's with the shifter, come home park her up on a slight uphill, an now it wont come out of park..
Has this happened too anyone before ? Or maybe someone could point me too a old post where this has happen..
I'm really boggled over this one any help would go a treat
Post Posted: Sat Aug 17, 2013 8:16 pm
Locked into gear with the uphill?
Pull really hard?
Failing that, jack the rear diff off the ground and try.
Post Posted: Sat Aug 17, 2013 8:17 pm
Yeah, I'd reef on it a bit harder. Your handbrake may not be working as well as it should
Post Posted: Sat Aug 17, 2013 8:23 pm
get some one to rock it/push it forwards so the parking pawl can onload while trying to shift it.
Post Posted: Sat Aug 17, 2013 8:24 pm
Pull really hard?
Yeah we done this, had to jack the rear off the ground too roll the truck back in the end soo we could close the garage door lol an still its stuck in park
Post Posted: Sat Aug 17, 2013 8:26 pm
Oh yes good point we are yet to try this, we did rock it back a forward really hard, but no one in the truck trying to select a gear a the time
Post Posted: Sat Aug 17, 2013 8:31 pm
Hand brake works well, An we were taking some frustration out wiliest reefing, too the point where the diff was making some unattractive thumping sounds :lol: an still no go...
Post Posted: Sat Aug 17, 2013 8:33 pm
Is there an emergency transmission release on the vitara trans ???
Post Posted: Sat Aug 17, 2013 8:47 pm
no i don't think so... there is a neutral start switch override.
Post Posted: Sat Aug 17, 2013 9:30 pm
just for the sake of simplicity take the cover off from the shifter and see if the detent pin is actually going all the way down when you push the button in.
The shifter from my donor vitara is a bit finicky like this which can make it a bit difficult to move from the park position, I think the nylon rod inside it has worn a bit.
Users browsing this forum: No registered users and 85 guests
